Perform calculations using neighbouring cell data
Old   July 26, 2021, 08:14
Default Perform calculations using neighbouring cell data
Elliott Sutton
Ells96 is on a distinguished road
Hi everyone,
I'm quite new to programming with OpenFOAM and need some help.
I am trying to create a new scalar field that calculates the total difference in viscosity between a given cell and all of its neighbouring cells. What is the syntax I need to get the value of a variable in a given cell and the value in all cells directly adjacent?
I'm hoping to get this to work for an AMR method and to work in parallel.
Thanks,
Elliott
Ells96 is offline   Reply With Quote
Old   July 26, 2021, 13:43
Michael Alletto
mAlletto will become famous soon enough
How to get the neighbour of one cell?
Just a few seconds googling helps a lot
mAlletto is offline   Reply With Quote
Old   August 3, 2021, 07:01
Elliott Sutton
Thank you for this.
I've performed the calculation as shown below, but receive the error that " 'celli' was not declared in this scope". I'm not sure how to properly declare 'celli' as any cell in the mesh. Any help would be appreciated.
Declaration of the variable in the .C file, initialised based on a viscosity field:
    etaGrad_
        IOobject
            "etaGrad" + name,
            U.time().timeName(),
            U.mesh(),
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        eta_
The actual calculation in .C:
   const objectRegistry& db();
   const volVectorField& U = db().lookupObject<volVectorField>("U");
   const fvMesh& mesh = U.mesh();
   const labelList& neighbour = mesh.cellCells[celli]();
   forAll(neighbour,celli)
      etaGrad_[celli] += mag(eta_[celli] - eta_[neighbour[celli]]);
Declaration in the .H file:
        //- Viscosity gradient field
        volScalarField etaGrad_;
neighbouring cells, parallel calculation, scalar field
[General] what is difference between point data and cell data? kyurinPark ParaView 1 June 19, 2018 19:49
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 01:51
paraview - cell data or point data on plot over line bye bye my blue OpenFOAM 0 December 13, 2016 07:07
Copy the data vector from a reference cell heksel8i OpenFOAM Programming & Development 0 December 2, 2016 17:51
[General] Creating 2D contour with Cell Data mutto233 ParaView 0 August 2, 2016 18:54
