dynamicSmagorinsky doesn't work when I load multiple libraries in controlDict
Old   July 10, 2021, 23:05
Default dynamicSmagorinsky doesn't work when I load multiple libraries in controlDict
Yi Wang
wangy11756010 is on a distinguished road
The dynamicSmagrinsky code is downloaded from Github (https://github.com/AlbertoPa/dynamicSmagorinsky) and it works when I run the test case. But when I want to use this model in my own case, I have met some problems. In controlDict file, I add these shared library files complied in FOAM_USER_LIBBIN as shown below.
libs
"libScaledMappedVelocityBCDelta.so"
"libOpenFOAM.so"
"libdynamicSmagorinskyModel.so"
When I run my simulation, I got these errors:
From void *Foam::dlLibraryTable:penLibrary(const Foam::fileName &, bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 188
Could not load "libdynamicSmagorinskyModel.so"
libdynamicSmagorinskyModel.so: cannot open shared object file: No such file or directory
But I ensure that the library is complied smoothly and I can run the test case. I think the reason is that I include two irrelavant library files simultaneously ("libScaledMappedVelocityBCDelta.so" and "libdynamicSmagorinskyModel.so"), maybe there are conflicts between them. Can anyone suggeet how can I resolve this problem?
Thanks in advance.
wangy11756010 is offline   Reply With Quote
Old   August 29, 2023, 13:01
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
Did you find a solution? I'm facing the same trouble. I'm using OpenFOAM v8
alainislas is offline   Reply With Quote
Old   August 29, 2023, 13:46
alainislas's Avatar
Alain Islas
This is from the OpenFOAM user guide (CFD direct), but it doesn't work. I believe it only reads my 1st library
complilation, les model, openfoam-v2012
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 05:01
Loading Libraries (e.g. new boundary conditions) Stored Locally in ControlDict dancfd OpenFOAM Running, Solving & CFD 3 May 15, 2022 14:53
First order in fvSchemes does not seem to work gerritgroot OpenFOAM Running, Solving & CFD 0 September 30, 2015 21:06
Are OSIG TurboMachinery libraries able to work under OpenFOAM-1.6-ext? alkochevsky OpenFOAM Installation 26 June 8, 2014 16:22
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
