June 28, 2021, 06:40 |
Store initial mesh - moving mesh
Rep Power: 5 |
Hello
I have developed a incremental mechanics solver able to deform the mesh at each time step by interpolating the displacement values at the mesh points. Now I'd need a method to "store" the initial mesh, before any deformation occurs, is there a way to do that? Thanks for any suggestion you will be able to provide |
June 28, 2021, 06:57 |
#2 | |
Mark Olesen
Rep Power: 40 |
You normally don't do that. Instead you use the points0() member from the motion solver. |
June 28, 2021, 09:03 |
Rep Power: 5 |
June 28, 2021, 14:54 |
Mark Olesen
Rep Power: 40 |
In that case, look at what the motion solver has implemented for the points0() access and use similar code yourself.
incremental solver, initial mesh, mesh deformation, mesh update |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
