How to access vertex from face?
Old   June 25, 2021, 01:20
Default How to access vertex from face?
Jun
mykkujinu2201 is on a distinguished road
Dear forums,
As far as I know, vertex points can be accessed through mesh.points()[cellID].
However, I want to know how to access vertex point directly from faceID.
Furthermore, I want to get vertex coordinates for further calculation.
1. Is there a way to access pointID from faceID or vice versa?
2. Is there a way to access point coordinates from pointID?
primitvePatch seems to be related to this issue but I do not know exactly.
Best,
Jun
mykkujinu2201 is offline   Reply With Quote
Old   June 25, 2021, 07:52
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by mykkujinu2201 View Post
Dear forums,
Best,
Jun
It becomes quite easy once you understand how things are put together in OpenFOAM. A face is just a collection of labels (vertex indices) - it doesn't really care what it indexes into.
Suppose you have a face "f" from that you know is from the mesh. In that case the coordinates associated with the face are simply those from the mesh.
const label faceId = 100;   // face Id in mesh
const face& f = mesh.faces()[faceId];   // face in mesh
Info<< "face point 0: " << f[0] << nl;
Info<< "face point 0 coordinate: " << mesh.points()[ f[0] ] << nl;
olesen is offline   Reply With Quote
Old   June 27, 2021, 05:03
Jun
Dear Olesen,
Thank you for the reply.
I have more question.
If I am going to compute values at faces using the neighbour and the owner cells in parallel computation, will it work also? or should I do some other treatment?
Best,
Jun
[blockMesh] mergePatchPairs error (please help me out) ramhari OpenFOAM Meshing & Mesh Conversion 16 May 30, 2017 14:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
