June 24, 2021, 04:12 |
Compiling custom solver for profiling
Rep Power: 8 |
I have a custom solver and am trying to compile it with profiling options switched on. It's a code built on OpenFOAMv1912 and I compile the openfoam itself properly with the flags for the file 'wmake/rules/linux64Gcc/c++Prof' changed to: Code:
c++DBUG = -pg c++OPT = -O3 -finline -march=native -fno-omit-pointer Code:
/home/rku/OpenFOAM/OpenFOAM-v1912/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Prof/xxFvMesh/xxFvMesh.o' failed make: *** [Make/linux64GccDPInt32Prof/xxFvMesh/xxFvMesh.o] Error 1 wmake solvers/xx g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -finline -march=native -fno-omit-frame-pointer -pg -DNoRepository -ftemplate-depth-100 -I/home/rku/OpenFOAM/OpenFOAM-v1912/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/vectorTools -I/home/rku/OpenFOAM/OpenFOAM-v1912/applications/utilities/mesh/generation/extrude/extrudeMesh -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/TurbulenceModels/incompressible/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/transportModels -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/transportModels/incompressible/singlePhaseTransportModel -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/sampling/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/dynamicFvMesh/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/surfMesh/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/fvOptions/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/triSurface/lnInclude -I../../src/lnInclude -I../../src/include -IlnInclude -I. -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/rku/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Prof/xx.o -L/home/rku/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Prof/lib \ -lturbulenceModels -lincompressibleTurbulenceModels -lincompressibleTransportModels -lfiniteVolume -lmeshTools -lsurfMesh -lfvOptions -lsampling -ldynamicFvMesh -L/home/rku/OpenFOAM/rku-v1912/platforms/linux64GccDPInt32Prof/lib -lxxMethod-lOpenFOAM -ldl \ -pg -lm -o /home/rku/OpenFOAM/rku-v1912/platforms/linux64GccDPInt32Prof/bin/xx /usr/bin/ld: cannot find -lxxMethod collect2: error: ld returned 1 exit status Does anyone else have it as well? Or link it to something similar already posted.. Thanks again for all the help Cheers. |
openfoam 1912, profiling |
Duplicate library entries when running a solver with custom library | francescomarra | OpenFOAM Programming & Development | 3 | May 17, 2022 08:37 |
Poisson equation in custom solver diverges for large boundary values | babakflame | OpenFOAM Running, Solving & CFD | 2 | May 23, 2017 20:11 |
flow solver won't recognize custom library | hakonbar | OpenFOAM Programming & Development | 2 | April 7, 2014 08:09 |
Error compiling solver controlling custom BC | Gaetano | OpenFOAM Programming & Development | 2 | January 22, 2014 06:48 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
