Avoid drift in p_rgh
Old   June 20, 2021, 15:52
Red face Avoid drift in p_rgh
asier
zuba is on a distinguished road
Hello
I have a problem with a simulation of a plume (dry air 60% + CO2 40%) into the atmosphere. I am running into problems partly because of my lack of experience with CFD and compressible fluids in particular. The model includes a wind of 1-15 m/s and a non-flat topography in the bottom. I use rhoReactingBuoyantFoam to simulate it without reactions and with the combustion off. I do so because I need a gas concentration varying with the time in each cell. The solver computes p_rgh instead of p. The simulation runs until the end (1000 s), but the pressure increases from 100kPa until ~200 kPa (2 atm). I would like to avoid this drift of the pressure, but I cannot figure out how or if it is possible even. I have tried optimizing the boundary conditions without any effect. I also tried a "brute force" approach where p_rgh is shifted so that its value is pRefValue at a reference cell in the end of each calculation loop. I do so adding the following line:
p_rgh += pRefValue - p_rgh0
pRefValue=dimensionedScalar with a reference value in Pa.
p_rgh0=dimensionedScalar with the value of p_rgh in a cell that I use as reference in the bottom of the calculation domain.
This last "trick" avoids the drift but it prevents the convergence of the outerloop of PIMPLE. This is not a problem for me because the "inner loops" converge well and I am only interested in the stationary state. However, I do not understand why does not converge. The only problem I could find in the output log is with the continuity error. The cumulative error goes to -6 very fast.
Does anybody know why the "brute force" method breaks the convergence of the outer loop of PIMPLE? The Navier-Stokes equation has only derivatives of the pressure and a constant should not change the equation.
Does anybody have any suggestion?
Thank you
zuba is offline   Reply With Quote
pressure drift, p_rgh, rhoreactingbuyantfoam
snappyHexMesh parallel, avoid reconstructParMesh Tom Lauriks Main CFD Forum 2 April 27, 2020 12:47
How to avoid the pebble-pebble contact liulimin STAR-CCM+ 0 October 25, 2016 23:47
VOF bubble drift velocity niriosrat STAR-CCM+ 1 October 18, 2016 10:01
how to avoid self intersection:Proam bala Siemens 5 March 6, 2008 05:23
The drift flux model Ben Main CFD Forum 0 March 22, 2006 07:10
