Patch Extraction through code is giving a problem
Old   June 12, 2021, 11:46
Default Patch Extraction through code is giving a problem
Sunag R A
sunagra27 is on a distinguished road
Dear all,
I want to extract a patch from the domain, so I wrote the code as shown below. Basically, the domain consists of 2 patches. I want to extract a particular patch for which the code is correct.
But, I get the patch with incomplete faces although it shows the exact no of faces present in the patch.
1. I saved the faceLabels in a ".txt" file. Used this facelabel in topoSet as "LabelToFace" and converted to VTK using "foamToVTK" for visualization.
2. What is wrong in the code, so that it shows incomplete patch although it shows correct amount of faces and also I believe that the faceLabel alignment is not proper.
3. Code
code
        const fvPatch& mesh = this->patch();
        const fvBoundaryMesh& boundaryMesh = mesh.boundaryMesh();
        for (int patch = 0; patch < 1; patch++)
            const word& patchName = mesh.boundaryMesh()[patch].name();
            Info << patchName << endl;
            const fvPatch& cPatch = mesh.boundaryMesh()[patch];
            std::ofstream file;
            file.open("faceID.txt");
            forAll (cPatch, faceI)
                label faceId = cPatch.start() + faceI;
                //Info << faceId << endl;
                file<< faceId << endl;
                file<< nl << endl;
            file.close();
4. Images
a. Patch I needed: Below is the patch that I needed.
https://drive.google.com/file/d/1KUq...ew?usp=sharing
b. Patch I am obtaining: Below is the patch based on code. We can see it is an incomplete patch.
https://drive.google.com/file/d/1Rdi...ew?usp=sharing
Any leads will be appreciated.
Thanks and Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
development, mesh manipulation, openfoam, patch, toposet
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
