Access probe function object from post processing code
Old   May 27, 2021, 10:47
Default Access probe function object from post processing code
Agavi is on a distinguished road
Hi everyone!
I am not really experienced in OpenFOAM programming but am writing a post processing utility (based on postChannel), and would like to access the probes function object. My utility should be able to read the coordinates as well as the time series results of the probes function object.
I'm pretty sure I'll have to read the flow field values of the probes ''manually'' since it is probably not registered anywhere in the case setup, but I was wondering if there is a good way to access at least the coordinates of the 'probes' function object, in a smarter way than just reading the postProcessing/probes/0/U file. (Defining a probe object and get the list of probes from there).
Also, I wonder if there is an 'OpenFOAM-based' way to read the time series in the postProcessing/probes/0/U file (see photo). Can I define it as an IOStream and read it so that I can directly input the (x y z) streams into openfoam vectors?
Thank you!
Agave
Agavi is offline   Reply With Quote
access probes class, iostream
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
How to access my topoFvMesh member function in my code? Cyp OpenFOAM Programming & Development 2 November 8, 2016 11:31
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 12:59
