Boundary condition for epsilon as a function of k, y, z and time |
May 12, 2021, 11:12 |
Rep Power: 5 |
Hi all,
I want to set a boundary condition for epsilon on topSurface in my channel which is a function of k and coordinates y and z. It shall also take the k data from the topSurface for each iteration (time dependent) and calculate epsilon accordingly. I am using v2012 and v 8.0. What would be the best way of doing it? With the help of one member I tried to create a new boundary condition. The member function is as follows: // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // Code:
void Foam::epsilonFreeSurfaceFvPatchScalarField::updateCoeffs() { if (updated()) { return; } const IOdictionary& d = static_cast<const IOdictionary&>(dict.parent().parent()); const fvMesh& mesh = refCast<const fvMesh>(d.db()); const label id = mesh.boundary().findPatchID("topSurface"); const fvPatch& patch = mesh.boundary()[id]; const scalar t = this->db().time().timeOutputValue();//Get the current time step const volScalarField& k = mesh.lookupObject<volScalarField>("k"); scalarField kp = k.boundaryField()[id]; scalarField epsp(patch.size(), 0.0); if (t >= t) //Perform calculation at each time step //Info << "t = " << t << endl; { forAll(epsp, facei) { scalar y_ = patch.Cf()[facei].y(); scalar z_ = patch.Cf()[facei].z(); scalar k_ = kp[facei]; epsp[facei] = k_*y_*z_; //say } } } error: ‘dict’ was not declared in this scope Do I need to do anything about the write entry for epsp also? Is the time calling is okay? Any help in improving/modifying/correcting the code would be highly appreciated. Thank you. Last edited by subhojitkadiacfd; May 15, 2021 at 06:55. |
May 13, 2021, 10:43 |
Rep Power: 5 |
I have successfully compiled the boundary condition Code:
............................../mnt/c/Windows/System32/epsilonFreeSurface$ wmake libso wmake libso (epsilonFreeSurface) Making dependency list for source file epsilonFreeSurfaceFvPatchScalarField.C g++ -std=c++11 -m64 -pthread -DOPENFOAM=2012 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v2012/src/meshTools/lnInclude -iquote. -IlnInclude -I/opt/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v2012/src/OSspecific/POSIX/lnInclude -fPIC -c epsilonFreeSurfaceFvPatchScalarField.C -o Make/linux64Gcc63DPInt32Opt/epsilonFreeSurfaceFvPatchScalarField.o g++ -std=c++11 -m64 -pthread -DOPENFOAM=2012 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v2012/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v2012/src/meshTools/lnInclude -iquote. -IlnInclude -I/opt/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v2012/src/OSspecific/POSIX/lnInclude -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc63DPInt32Opt/epsilonFreeSurfaceFvPatchScalarField.o -L/opt/OpenFOAM/OpenFOAM-v2012/platforms/linux64Gcc63DPInt32Opt/lib \ -lfiniteVolume -lmeshTools -o /home/subhojik/OpenFOAM/subhojik-v2012/platforms/linux64Gcc63DPInt32Opt/lib/libepsilonFreeSurface.so But when running the simulation I am getting the following error Code:
--> FOAM Warning : From void* Foam::dlLibraryTable::openLibrary(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 188 Could not load "libepsilonFreeSurface.so" /..........................v2012/platforms/linux64Gcc63DPInt32Opt/lib/libepsilonFreeSurface.so: undefined symbol: _ZTIN4Foam36epsilonFreeSurfaceFvPatchScalarFieldE Create mesh for time = 0 [1] --> FOAM FATAL IO ERROR: (openfoam-2012) [1] Unknown patchField type epsilonFreeSurface for patch type patch Last edited by subhojitkadiacfd; May 15, 2021 at 06:57. |
May 15, 2021, 09:50 |
Rep Power: 5 |
Many thanks Tobi for you suggestion.
How can I access the k values for every iteration (time step)? Subhojit |
May 15, 2021, 12:23 |
Tobias Holzmann
Rep Power: 52 |
Use google to get more information regarding the codedFixedValue condition.
You can get easy access to the "k" field inside the "epsilon" using something link that: Code:
const volScalarField& k = this->db().lookupObject<volScalarField>("k"); // Then you need to get access to the patch fields and to the corresponding boundary Keep in mind, «k» does not represent the turbulentKineticEnergy here and I worked with templates here. You don't have to take care about time-steps etc. Whenever we solve the matrix equations, we update the boundaries, hence we always do have actual values here.
Keep foaming, Tobias Holzmann |
May 15, 2021, 16:44 |
Herpes Free Engineer
Rep Power: 13 |
In addition to Tobi's remarks, I would also give a try to use PatchFunction1 which allows you to use a myriad of ways to manipulate boundary conditions in a much generic way.
You can then use a coded or expression-based boundary condition or any other Function1 input types in your input dictionary by using PatchFunction1 in your code. You can find some examples in the boundary conditions under src/atmosphericModels. Hope helps.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 16, 2021, 05:12 |
Tobias Holzmann
Rep Power: 52 |
good hint but at the end it is equal to the codedFixedValue if he uses the code Function1 option. As he wants to have access to other fields in the boundary condition, one needs to use a coded one - don't matter if it is the uniformFixedValue or codedFixedValue. Al least as far as I know Nevertheless, I agree, one can also use the uniformFixedValue condition.
May 16, 2021, 05:47 |
Rep Power: 13 |
If both options would require the same effort, I would use the generic one. Though, PathFunction1 would be a bit more involved. Depends what the inquirer wants. Both ways are good, anyhow.
May 16, 2021, 11:57 |
#9 |
Rep Power: 5 |
Many thanks Tobi and HPE for your valuable suggestions. As per my understanding I have tried the following two options:
Case1 Code:
topSurface { type codedFixedValue;//changing with k value uniform 0.00346; name myEpsilonFS; code #{ const scalar b = 0.3; //channel width b (m) const scalar h = 0.106; // flow depth h (m) const fvMesh& mesh = patch().boundaryMesh().mesh(); const label id = mesh.boundary().findPatchID("topSurface"); const fvPatch& boundaryPatch = mesh.boundary()[id];; const volScalarField& k = this->db().lookupObject<volScalarField>("k"); scalarField kp = k.boundaryField()[id]; scalarField epsilon(boundaryPatch.size(), 0.00346); forAll(epsilon, facei) { const scalar y_ = boundaryPatch.Cf()[facei][1];// 1 for y coordinate, 2 for z coordinate const scalar z_ = boundaryPatch.Cf()[facei][2]; const scalar y1_ = 0.07*h; const scalar y2_ = min((0.5*b - mag(z_)), mag(y_)); const scalar k_ = kp[facei]; epsilon[facei] = 0.391*pow(k_, 1.5)*(1.0/y1_ + 1.0/y2_); } // epsilon (free surface) = 0.391*k(free surface)^3/2*(1/y*+1/y') #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude\ -I$(LIB_SRC)/meshTools/lnInclude\ -I$(LIB_SRC)/TurbulenceModels/lnInclude #}; codeInclude #{ #include "fvCFD.H" #include <cmath> #include <iostream> #}; codeLibs #{ -lfiniteVolume -lmeshTools #}; } Code:
........... code #{ const scalar b = 0.3; //channel width b (m) const scalar h = 0.106; // flow depth h (m) const fvPatch& boundaryPatch = this->patch(); const vectorField& Cf = boundaryPatch.Cf(); const label& patchLabel = boundaryPatch.index(); const volScalarField& k = this->db().lookupObject<volScalarField>("k"); fvPatchScalarField kp = k.boundaryField()[patchLabel]; scalarField& field = *this; forAll(Cf, facei) { const scalar y_ = Cf[facei].y(); const scalar z_ = Cf[facei].z(); const scalar y1_ = 0.07*h; const scalar y2_ = min((0.5*b - mag(z_)), mag(y_)); const scalar k_ = kp[facei]; field[facei] = 0.391*pow(k_, 1.5)*(1.0/y1_ + 1.0/y2_); } // epsilon (free surface) = 0.391*k(free surface)^3/2*(1/y*+1/y') #}; ............ Could you please check the code and let me know if I need any corrections? Thanks. Subhojit |
May 16, 2021, 16:41 |
#10 |
Tobias Holzmann
Rep Power: 52 |
In the codedFixedValue you need the operator==
operator==(epsilon); However, the second one should work. If the values do not fit, you have to check it. We cannot give you an answer on your calculation.
May 22, 2021, 16:45 |
#11 |
Rep Power: 5 |
Hi Tobi,
Many thanks for your suggestions. The code is working properly. Hoping to get the desired result soon. Subhojit |
June 7, 2021, 07:49 |
#12 |
Rep Power: 5 |
Further improvement was required, so I tried to calculate the average distance from the wall. I added the following code within the codedFixedValue condition
forAll(Cf, facei) { const scalar z_ = Cf[facei].z();// lateral coordinate of the face centre const scalar y_1 = 0.07*h; const scalar z_1 = 0.5*b - mag(z_);// horizontal distance from the left wall const scalar k_ = kp[facei]; if (z_1 <= h) { const int n_1 = 100; // taking 100 parts along the flow depth const scalar delta_h = h/n_1; const scalar sum_1 = 0.0;// initial value for (int i = 0; i <= n_1; ++i) { const scalar h_1 = delta_h*i; const scalar d_1 = sqrt(sqr(h_1) + sqr(z_1));// distance between the points const scalar sum_1 = sum_1 + d_1; } const scalar y_2 = sum_1/(n_1 + 1);// average distance epsilon[facei] = 0.401*pow(k_, 1.5)*(1.0/y_1 + 1.0/y_2); } ....... ....... Thanks in advance. Subhojit Last edited by subhojitkadiacfd; June 8, 2021 at 07:04. |
June 8, 2021, 08:05 |
#13 |
Tobias Holzmann
Rep Power: 52 |
Not sure what you calculate but in a programming point of view there are some mistakes. I just grab one snippet:
const scalar sum_1 = 0.0; for (int i = 0; i <= n_1; ++i) { const scalar h_1 = delta_h*i; const scalar d_1 = sqrt(sqr(h_1) + sqr(z_1)); const scalar sum_1 = sum_1 + d_1; } const scalar y_2 = sum_1/(n_1 + 1); After that you jump into the for-loop and you define another variable that takes the same name as before. Note, as you are inside a sub-frame (no idea about the correct name), you can create the same variable again but it is not the same as before - it is a new one. The validity of this second sum_1 ends after the bracket and it does not exist anymore. Example: Code:
const scalar foobar = 1; // Variable 1 const scalar foobar = 2; // Variable 2 - compiler error as foobar already exists Code:
const scalar foobar = 1; // Variable 1 { const scalar foobar = 2; // Variable 2 - no compiler error } Code:
const scalar foobar = 1; // Variable 1 { Info << foobar << endl; // Will return 1 as we check Variable 1 // This definition of the object "foobar" will hide the previous defined one // No possible chance to access Variable 1 const scalar foobar = 2; // Variable 2 - no compiler error Info << foobar << endl; // Will return 2 as we check Variable 2 } // After that bracket, the Variable 2 is not valid anymore Info << foobar << endl; // Will return 1 as we check Variable 1 Now the semi-correct on: Code:
const scalar foobar = 0; foobar = 2; // Compiler error as foobar is in read-only mode (const) Code:
scalar sum_1 = 0.0; for (int i = 0; i <= n_1; ++i) { const scalar h_1 = delta_h*i; const scalar d_1 = sqrt(sqr(h_1) + sqr(z_1)); sum_1 += d_1; }
Keep foaming, Tobias Holzmann Last edited by Tobi; June 8, 2021 at 09:33. |
June 8, 2021, 08:41 |
#14 |
Rep Power: 5 |
Many thanks Tobi.
boundary condition, codedfixedvalue |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
