Input for porousMedia via fvOptions
Old   May 11, 2021, 07:48
Default Input for porousMedia via fvOptions
Chris
Pyrokrates is on a distinguished road
I would like to change the way, I can input porosity for my medium. I know that i can use fvOptions to define porous media and set d and f coeffs. I would like to define this locally later on due to inhomogeneous material and porosity. I know I could define multiple cellZones for each permeability to set d and f local but I need to do this with thousands of cells meaning the better way for me would be to give a field of d and f coeffs out of another program (in my case python calculates K local) instead of hundreds of porostiy zones.
Now I would like to change the input but I dont understand the whole file system.
What I know so far:
1) porousSimpleFoam uses Ueqn.H with fv.Options(U) on right hand side. Thats why I need to use #include "fvOptions.H" at porousSimpleFoam.C.
2) Now the part that confusing me starts.
2.1) fvOptions.C and fvOptions.H are also coupled with fvOption.C and fvOption.H and same with fvOptionList. But I cant finde the connection to DarcyForchheimer.H and DarcyForchheimer.C. This construct seems too confusing for me :/
2.2) To solve Ueqn and peqn I need to import the .H files with the equations. For DarcyForchheimer the equations are at the .C files... I thought .H are header files to define Variables etc. and .C are the scource files to solve equations or am I wrong with this.
If I could understand all the connections I may be able to replace all this and pass a field of K or directly d and f coeffs to the field of DarcyForchheimer equations for calculating the results.
Thanks in advance for any help.
Chris
Pyrokrates is offline   Reply With Quote
Correct foamfile header for input file with mixed quantities (any version of OF) deepbandivadekar OpenFOAM Running, Solving & CFD 3 February 15, 2021 06:10
What are the units used in the thermophysicalProperties and fvOptions dictionaries? ophr OpenFOAM Pre-Processing 2 June 16, 2019 02:29
Configuration of boundary conditions and fvOptions file Raza Javed OpenFOAM Running, Solving & CFD 16 May 3, 2019 17:35
Power and Enthalpy in fvOptions file Raza Javed OpenFOAM Running, Solving & CFD 1 April 26, 2019 11:03
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
