Method of manufactured solutions for rhoSimpleFoam |
May 10, 2021, 18:57 |
Bruno Ramoa
Rep Power: 7 |
Hello to all,
I am trying to use the method of manufactured solutions (MS) to verify rhoSimpleFoam. However, I am quite new to this methodology and would like to have some feedback from you guys. rhoSimpleFoam solves the compressible navier-stokes equation (steady-state): https://openfoamwiki.net/index.php/RhoSimpleFoam I am running a 2D case. I have manufactured a solution for u, v and density and am keeping the temperature constant at 393.15K. I am using the perfectGas Equation of State (EoS) and a constant viscosity model (mu = 1 Pa.s). The MS for density is inserted into the pressure equation through the fvOptions at line 63 of pEqn.H. The MS for the momentum equation is inserted through fvOptions at line 11 of UEqn.H My doubt is: Should I compute a pressure term from the EoS with the MS for density and use it in the computation of the source terms for the momentum equation? Can I keep the temperature as a constant or should also create a MS for Temperature? Would appreciate insight into this method. Kind regards |
Method of Manufactured Solutions - Turbomachinery | TurboFlo | Main CFD Forum | 7 | September 25, 2019 19:46 |
double-projection method that works on non-staggered grid | zx-81 | Main CFD Forum | 3 | February 12, 2017 05:23 |
Turbulence inflow generation - recycling method | panda60 | OpenFOAM Running, Solving & CFD | 15 | April 25, 2013 02:34 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 11:55 |
Comparison: Finite Volume Method vs. Analytic Method | m-fry | Main CFD Forum | 1 | April 20, 2010 15:40 |
