Strange behaviour with a custom utility while running in parallel |
April 30, 2021, 11:43 |
MNM
Rep Power: 9 |
Dear Foamers,
I'm trying to implement a Pre - processing utility (customField) in parallel to initialize a volVectorField (H) within a 3D domain. It involves integration of a piecewise function based on axial coordinate of the geometry. The function involves the Bessel function (Foam::j0 & Foam::j1) and sample code is shown below Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2021 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application customField Description \*---------------------------------------------------------------------------*/ #include "fvCFD.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "readSolenoidDict.H" #include "createHField.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.run()) { runTime++; Info<< "Time = " << runTime.timeName() << nl << endl; const vectorField& CC = mesh.C(); const scalarField x1 = CC.component(vector::X); //Extracting the x cordinates of cell centre const scalarField y1 = CC.component(vector::Y); //Extracting the y cordinates of cell centre const scalarField z1 = CC.component(vector::Z); //Extracting the z cordinates of cell centre scalarField Hx(mesh.nCells(), 0.); // Initialize Hx over each cell scalarField Hy(mesh.nCells(), 0.); // Initialize Hy over each cell scalarField Hz(mesh.nCells(), 0.); // Initialize Hz over each cell scalarField GG1(mesh.nCells(), 0.); // Initialize custom var GG1 = (Lcend - Z) over each cell scalarField GG2(mesh.nCells(), 0.); // Initialize custom var GG2 = (Lcstart - z) over each cell scalarField unity(mesh.nCells(), 1.0); ////declaring dummy scalar field for for ease of computations over all cells scalarField rho = Foam::sqrt((x1*x1)+(y1*y1)) ; // Declaring the cylindrical coordinate r scalarField Rcoil = 0.5*Ds.value()*unity; scalarField SHD = (Rcoil*Nt.value()*Ic.value())/(2*Ls.value()); forAll(H,celli) { rho[celli] = Foam::sqrt((x1[celli]*x1[celli])+(y1[celli]*y1[celli])) ; // Declaring the cylindrical coordinate r GG1[celli] = Lcend.value() - z1[celli]; GG2[celli] = Lcstart.value() - z1[celli] ; //*************************************For z coordinate smaller than LEFT BOUND********************************************// if (z1[celli] <= Lcstart.value() ) { //###### Axial H for (int no = 1; no<=Naxout; no++) { Hz[celli] += (-SHD[celli])*(1*Foam::j0(no*rho[celli]))*(1*Foam::j1(Rcoil[celli]*no))* ((1*Foam::exp(no*(-GG1[celli]))) - (1*Foam::exp(no*(-GG2[celli])))); } } //*************************************For z coordinate greater than RIGHT BOUND********************************************// else if (z1[celli] > Lcend.value() ) // { //###### Axial H for (int no = 1; no<=Naxout; no++) { Hz[celli] += (SHD[celli])*(1*Foam::j0(no*rho[celli]))*(1*Foam::j1(Rcoil[celli]*no))* ((1*Foam::exp(no*GG1[celli]))-(1*Foam::exp(no*GG2[celli]))); } } //*************************************For z coordinate between BOTH BOUNDS********************************************// else { //###### Axial H for (int ni = 1; ni<=Naxin; ni++) { Hz[celli] += (-SHD[celli])*(1*Foam::j0(ni*rho[celli]))*(1*Foam::j1(Rcoil[celli]*ni))* ((1*Foam::exp(-ni*GG1[celli])) + (Foam::exp(ni*GG2[celli])) - (2.0)); } } //*********************************************************************************************************************// H[celli] = vector(Hx[celli], Hy[celli], Hz[celli]); } runTime.write(); Info<< nl << "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************************************* // However, to reduce the time required for integration, I'm trying to run it using mpirun. Now, When the number of terms of integration are small (around 100), the utility works correctly and write the generated field in the subsequent processor dictionaries. Using this I can correctly reconstruct the field for the whole domain. But if we go for higher values (around 10,000) for Naxin, Naxout, the "reconstructPar" will throw an error of "No times selected". The error is expected as for higher Naxin, Naxout the utility writes no output in corresponding processors It'll be really helpful if someone can comment on what is going wrong here ? P.S. Naxin and Naxout are scalar inputs provides using an I/Odictionary whereas Nt, Ic, Ds Ls, Lcstart, and Lcend are provided as dimensionedScalar I'm using OpenFOAM 5.0 |
May 3, 2021, 03:29 |
#2 | |
Mark Olesen
Rep Power: 40 |
custom utility, openfoam, parallel |
environment variable MPI_BUFFER_SIZE not defined when running a parallel case | rokasbytautas | OpenFOAM Bugs | 0 | January 18, 2021 07:41 |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 14:13 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 23:04 |
parallel running | student666 | OpenFOAM Running, Solving & CFD | 7 | May 21, 2014 15:55 |
