some confusion about "Make/options"
Old   April 26, 2021, 04:25
Default some confusion about "Make/options"
warner chang
warnerchang is on a distinguished road
Hi! Foamers.
when I was compiling a new solver, I was confused about how to include proper files/libraries in the Make/options?
some codes as follow:
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools
Does somebody has any ideas?
And One more question! Are the libraries which are included in Make/options in /home/***/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/lib
warnerchang is offline   Reply With Quote
Old   May 3, 2021, 18:58
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The libraries listed as EXE_LIBS are all "proper" libraries, it just happens that the standard OpenFOAM library location is added automatically. That is to say, there is an implicit -L$(FOAM_LIBBIN) there. If you need to add libraries from other locations, eg -L$(FOAM_USER_LIBBIN) -lyourlib, or -L/cluster/path/lib64 -lsomeOther, you need to specify that.
olesen is offline   Reply With Quote
Old   May 4, 2021, 06:43
warner chang
Hi! olesen
Thank you for your help! I am confused about the prefix -L, in my codes, it is started by -l, is there any difference between -L and -l?
And what is the difference between EXE_INC and EXE_LIBS? I mean that they both contian "finiteVolume" and "meshTools". What EXE_LIBS contains is source files? and what EXE_INC contains is just dynamical links?
Appreciate for your reply!
Old   May 7, 2021, 02:39
Mark Olesen
Originally Posted by warnerchang View Post
Hi! olesen
dynamical links?
"man gcc" and you will see what they mean
Old   May 8, 2021, 18:58
Tobermory will become famous soon enough
You need to read up a little on compilation, as Mark suggests. In particular - learn about the role of include files (-I) during compilation, and the role of a linker in building an executable or library. Once you understand that, all will be clear!
Tobermory is offline   Reply With Quote
Old   May 9, 2021, 03:31
warner chang
Thank you for reply!
Best regards!
Confusion choosing between static / transient simulations TharunSK CFX 1 March 15, 2019 18:53
some confusion about the radiation model of Floefd jason kid FloEFD, FloWorks & FloTHERM 4 March 3, 2016 08:13
[waves2Foam] have some confusion about the parameter Tsoft zhxter OpenFOAM Community Contributions 1 January 21, 2015 16:34
Sub-domain Confusion Flaky CFX 6 October 7, 2010 08:40
Avoiding Code Confusion Jonas Larsson CFX 3 April 18, 2001 04:44
