error: no match for ‘operator/’ (operand types are ‘Foam::SphericalTensor<double>’
Old   April 20, 2021, 02:15
Default error: no match for ‘operator/’ (operand types are ‘Foam::SphericalTensor<double>’
Alberto Campuzano
baezacaljo is on a distinguished road
Good afternoon dear all
i am quite new using openFoam and i am facing the next error when i tried to compile my code
error: no match for ‘operator/’ (operand types are ‘Foam::SphericalTensor<double>’ and ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’)
i am following some tutorials and info about plasticSolver in openfoam. However, they only apply for the previous version of openfoam.
(BTW let me tell you that i took the solidDisplacementFoam solver as a base case and i started doing my modifications)
when i am trying to compile my file called calculateStress.H the previous mentioned error appears.
i am guessing that such error appears when i am trying to make a multiplication by a variable. see the code next.
        forAll(fac, celli)
            if (fac[celli] > 1.0)    //Plasticity occurs
                sigma[celli] = 1.0/3.0*I*tr(sigma[celli]) + dev(sigma[celli])/fac[celli];
                symmTensor dsigma = sigma[celli] - sigma_old[celli];
                tensor deps_e = (1.0/3.0*I*tr(dsigma))/(3.0*lambda+2.0*mu)
                              + dev(dsigma)/(2.0*mu);
                tensor deps = 1.0/2.0*(graddD[celli] + graddD[celli].T());
                deps_p[celli] = deps - deps_e;
            else    // only elasticity
                deps_p[celli] = tensor::zero;
the error relies exactly on the next line
when i remove the variable volScalarField mu and volScalarField lambda the code compiles.
any suggestions?
what can i do?
Thanks in advance
Alberto
baezacaljo is offline   Reply With Quote
Old   April 27, 2021, 11:50
Yang Zhe
Yang Zhe is on a distinguished road
I am also implementing the same code in openFOAM4.0 now.
but I encountered the following error:
calculateStress.H:43:49: error: no match for ‘operator=’ (operand types are ‘Foam::SymmTensor<double>’ and ‘const Foam::Tensor<double>’)
Is there anybody could solve this problem?
Yang Zhe is offline   Reply With Quote
Old   April 27, 2021, 13:26
Alberto Campuzano
Hi Yang Zhe. Look. Did you already tried to comment out the line
if it compiles, change tensor::zero for another value and you will se what's the real problem.
I haven't solve mine, but it seems to me that your code compiles the lines on which I am struggling.
We have to keep doing trial and error.
Best regards
Alberto Campuzano
Old   April 27, 2021, 23:12
Yang Zhe
Thanks a lot !
It passed by your suggestion.
like this:
deps_p[celli] = I;
As for your problem, I am also facing with it now and I cannot solve it.
I think there are some missing rules controlling the calculation between tensors and scalars in openFOAM 4.0 (at least for 4.0 ). And I have referred to this book before:
http://foam.sourceforge.net/docs/Gui...mmersGuide.pdf
But it did not work. What a pity !
I would be very appreciated if you can recommend some reference books to me !
Old   May 3, 2021, 20:55
Alberto Campuzano
Thanks a lot !
like this:
deps_p[celli] = I;
Hi Yang Zhe
I ve been searching for answers. However, nothing comes out.
Take a look, at the next link (Awesome slides from Philip Cardiff)
https://www.researchgate.net/profile...am-toolbox.pdf
Check the slide 109. Look, there are solving the system which we are looking for.
I think that applying the code from old OF versions (lets say you make your own code about solids taking as a references codes from old OF versions) and compiling it in new OF versions is a bad idea, usually compatibility problems are within the path.
what i did is this, compile from source foam extended 4.0 in Ubuntu 20.04 after i compiled solids4Foam, in there already exist the solver that we are looking for.
Notice, that now we have the advantage to take a look of the original code, copy it and try to compile it in OF8, and now we will see if our problem comes with compatibility or was a silly mistake in the code.
Best Regards
Alberto
openfoam 8, programming
Errno = 1 in OpenFOAM rfiore1 OpenFOAM Bugs 2 November 1, 2022 18:35
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
Match Control and Symmetry Boundary Condtions in a quasi 2D calculation peterputer ANSYS Meshing & Geometry 0 May 15, 2012 09:53
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
