How to modify and recompile file in src/finiteVolume/cfdTools |
Rep Power: 6 ![]() |
Hello foamers,
I would like to modify the Darcy-Forcheymer model to do some simulation with porous media. I found the source file in '/openfoam8/src/finiteVolume/cfdTools/general/porosityModel/DarcyForchheimer', copied the file, modified it but now I am stuck because I don't know how to recompile everything to make it work. So the question, how much of the total OF do I have to recompile ? Is there a quick way to make it work ? Thank you |
#2 | |
Ricky
Rep Power: 12 ![]() |
Hello!
Have a look at this presentation (from slide 8) --> https://www.google.com/url?sa=t&rct=...sO8JbL6p280tAN Hope this helps! Regards, Ricky Quote:
If it is easy, then something is fishy! |
#3 | |
Thanks !!!
cfdtools, compilation, openfaom-8, porosity; fvoptions |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
OpenFoam Recompile, successful but test is slow | hpc_benchmark | OpenFOAM Installation | 0 | January 15, 2010 21:15 |
