Calculate the viscous forces on a patch
Old   March 10, 2021, 04:53
Default Calculate the viscous forces on a patch
Jinghong Su
Su JH is on a distinguished road
Hello!
I am using foam-extend-3.2.
I want to obtain the forces and moments acting on a spherical particle in the channel flow. The forces and moments will be used to adjust the slip velocity on the particle surface. The forces are calculated by the script below and show to be different from the forces output by the libforces.so.
totalForce
type patchExpression;
outputControlMode timeStep;
enabled true;
outputInterval 1;
patches (
sphere_region0
// change to your name or names of patch
verbose true;
variables (
"position=0;"
"rho=1;"
"mu=1.0;"
"pressure_forces= rho*p*normal()*area();"
"viscous_forces= -mu*snGrad(U)*area();"
"forces=pressure_forces+viscous_forces;"
expression "forces";
accumulations ( sum );
Thank you in advance.
Su
Su JH is offline   Reply With Quote
patch, sngrad, swak4foam, viscous force
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
