sonicFoam: Supported energy type is e, thermodynamics package provides h
Old   March 3, 2021, 17:58
Default sonicFoam: Supported energy type is e, thermodynamics package provides h
mm66 is on a distinguished road
Dear Foamers,
I have been working with sonicFoam to get the pressure drop of a sonic flow. The default settings uses perfectGas as the equation of state:
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Consequently, the pressure drop values were very low. Therefore, I decided to switch to Peng-Robinson and according to the allowed combinations changed the thermoType to:
thermoType
    type            hePsiThermo;
    transport       sutherland;
    thermo          hConst;
    equationOfState PengRobinsonGas;
    specie          specie;
    energy          sensibleEnthalpy;
However, it returns the following error:
--> FOAM FATAL ERROR:
I tried with sensibleInternalEnergy but it also resulted in the following error:
unknown psiThermo type
Any ideas? I really appreciate any input here.
Thanks,
MJ
mm66 is offline   Reply With Quote
Old   April 2, 2021, 07:12
Jnana Bhaskar Rao
jnanabrao is on a distinguished road
It appears the sonicFoam energy equation is written for 'e', which should be internal energy. The rhoPimpleFoam solver's energy equation seems to be written for 'he' which I presume is enthalpy. I am aware that in the PIMPLE dictionary(in fvSolutions) for rhoPimpleFoam, in newer versions of OpenFoam(>6), rhoPimpleFoam can work equivalent to sonicFoam with a 'transonic' flag. Maybe this is what will work for you. Some newer OpenFoam versions have deprecated sonicFoam completely.
jnanabrao is offline   Reply With Quote
openfoam v1806, pengrobinsongas, sensibleenthalpy, sonicfoam, thermotype
time step continuity error increases with time_SRFSimplefoam mostafa kamal OpenFOAM Running, Solving & CFD 7 October 2, 2019 03:00
Compression instead of expansion EnricoDeFilippi OpenFOAM Running, Solving & CFD 1 October 8, 2018 11:19
multiphaseEulerFoam/tank discharge ves OpenFOAM Running, Solving & CFD 8 December 31, 2017 15:59
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 07:00
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
