Use oneThirdI and twoThirdsI in my own code
Old   March 3, 2021, 13:50
Default Use oneThirdI and twoThirdsI in my own code
Agustín Villa
agustinvo is on a distinguished road
In a certain part of a turbulence model I need to introduce the 2/3\delta_{ij} tensor (which is obviously symmetric). However, when I use twoThirdsI I get an error. Well, I don't even arrive to check it, but I got a huge list of notes, where I mostly understand I can't use it directly. Mi code contains:
tmp<fvSymmTensorMatrix> REqn
        fvm::ddt(alpha, rho, R)
      + fvm::div(alphaRhoPhi, R)
      - fvm::laplacian(alpha*rho*DREff(), R)
        alpha*rho*P
      + alpha*rho*oneMinusFn_*phiw  // velocity-pressure correlation at wall
      - fvm::Sp(alpha*rho*fn_*phiC1/2/k_,R)  // C1 implicit term  pressure
      + alpha*rho*fn_*
        ( phiC1* (b-dev(b))       // C1 explicit term  pressure
        + C2_*epsilon_*dev(innerSqr(b))   // C2 term
        + k_
             (C3_ - C3Star_*mag(b))*S                  // C3 Term
           + C4_*dev(twoSymm(b&S))                    // C4 Term
           + C5_*twoSymm(b&W.T())                     // C5 Term
      - fvm::Sp(alpha*rho*oneMinusFn_*epsilon_/k_,R)  // epsilon wall term
      - twoThirdsI*fn_*epsilon_//(b-dev2(b))*fn_*epsilon_                       // epsilon high term
      + fvOptions(alpha, rho, R)
A walkaround I found is to use (A-dev2(A)) where I ensure that I get 2/3\delta_{ij} but it is not the most elegant way. Have you ever tried to do something similar before?
agustinvo is offline   Reply With Quote
