Changing Viscosity in solver
Old   March 3, 2021, 01:36
Default Changing Viscosity in solver
mohammad
mostanad is on a distinguished road
Hi all,
I am working on the viscosity value in a multiphase solver. Due to some modifications, I need to change the viscosity value in the solver using a function in my defined class. So I used the following line to access the viscosity and change it.
volScalarField k_viscosity = turbulence->nu();
particleCloud.setParticleViscosity(k_viscosity);
However, by these lines, only the k_viscosity value is changed using call by reference in setParticleViscosity function. So how can give the modified k_viscosity to nu? I think that's a big question I couldn't find its answer.
Cheers,
Mohammad
mostanad is offline   Reply With Quote
Old   March 3, 2021, 18:55
mohammad
So interesting nobody knows the answer!
Old   March 3, 2021, 21:28
mohammad
Finally solved the problem by myself using a function, correctnu, like correct(), to update the viscosity in each time step.
class, coding, development, viscosity, volscalarfield
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 13:35
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
UDF for changing viscosity Rafael FLUENT 2 October 28, 2009 16:59
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
