adding condition to own solver (error occurs)
Old   February 23, 2021, 07:16
Default adding condition to own solver (error occurs)
John Kim
alexio97 is on a distinguished road
hello openfoamers.
I am trying to add condition
const dimensionedScalar& rhol = twoPhaseProperties_.rho1();
const dimensionedScalar& rhov = twoPhaseProperties_.rho2();
if (alpha1_<0.9 && alpha1_>0.01)
Q_pc_ = 1;
else
Q_pc_ = 0;
to my solver. But error
no match for ‘operator<’ (operand types are ‘const volScalarField {aka const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ and ‘double’)
occurs during allwmake.
Is there a way to solve this problem?
alexio97 is offline   Reply With Quote
Old   February 23, 2021, 08:00
Michael Alletto
mAlletto will become famous soon enough
alpha1_ is a volScalarField and you want to compare it with a scalar. This does not work since no operator is defined for this. You have to loop over the whole field and compere each entry
mAlletto is offline   Reply With Quote
Old   February 23, 2021, 08:34
Default thanks for the reply
John Kim
thanks for the reply! Then I have to make a code like this?
forAll(alpha1Cells, cellI)
if (alpha1[cellI] < 0.9 && alpha1[cellI] > 0.01)
Q_pc_ = 1;
else
Q_pc_[cellI] = 0;
Old   February 23, 2021, 08:38
Michael Alletto
forAll(alpha1_, cellI)
    if (alpha1_[cellI] < 0.9 && alpha1_[cellI] > 0.01)
        Q_pc_[cellI]= 1;
    else
        Q_pc_[cellI] = 0;
Something like this
Old   February 23, 2021, 08:46
John Kim
        Q_pc_[cellI]= 1;
    else
        Q_pc_[cellI] = 0;
Something like this
Thank you and I have one more question. I knew that i have to use const volScalarField& alpha1 but how can i get cell' alpha value? (like alpha1Cells). I noticed that
const volScalarField& alpha1 = alpha1();
scalarField& alpha1Cells = alpha1.internalField();
this doesn't work at openfoam 2.4.0
Old   February 23, 2021, 09:39
Michael Alletto
There were some changes regarding the name of the function which returns the reference to the internal field from 3.0 on. Just google
Old   February 25, 2021, 11:34
John Kim
        Q_pc_[cellI]= 1;
    else
        Q_pc_[cellI] = 0;
Something like this
Hello Michael, thanks for your reply. I tried your code and it worked. But i countered an error. Error is that if I apply Q_pc_ value with polynomials like pos(T_[cellI] - T_sat_)*h_lv_*rl*alpha1_[cellI]*rhol*((T_[cellI] - T_sat_)/T_sat_) + neg(T_[cellI] -T_sat_)*h_lv_*rv*(1.0 - alpha1_[cellI])*rhov*((T_[cellI] - T_sat_)/T_sat_);
The program thinks Q_pc_ as zero dimension. Can you help me to deal with the problem?
Old   February 25, 2021, 11:50
Michael Alletto
Can you post the error
Old   February 25, 2021, 11:52
John Kim
error: cannot convert ‘Foam::dimensioned<double>’ to ‘double’ in assignment
Q_pc_[cellI] = pos(T_[cellI] - T_sat_)*h_lv_*rl*alpha1_[cellI]*rhol*((T_[cellI] - T_sat_)/T_sat_) + neg(T_[cellI] -T_sat_)*h_lv_*rv*(1.0 - alpha1_[cellI])*rhov*((T_[cellI] - T_sat_)/T_sat_);
This is the error!
i think Q_pc_[cellI] = 0; is working well but the equation format does not work.
Old   February 25, 2021, 12:04
John Kim
This is the error!
my total code is like this
const word& name,
const dictionary& thermalPhaseChangeProperties,
const twoPhaseThermalMixture& twoPhaseProperties,
const volScalarField& T,
thermalPhaseChangeModel
name,
twoPhaseProperties,
T,
alpha1
Q_pc_
IOobject
"PhaseChangeHeat",
T_.time().timeName(),
T.mesh(),
IOobject::NO_READ,
IOobject::AUTO_WRITE
T.mesh(),
dimensionedScalar( "dummy", dimensionSet(1,-1,-3,0,0,0,0), 0 )
// reading rl and rv
thermalPhaseChangeProperties_.lookup("rl") >> rl;
thermalPhaseChangeProperties_.lookup("rv") >> rv;
correct();
// * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * //
void Foam::thermalPhaseChangeModels::EmpiricalRateParam eter::calcQ_pc()
else
Q_pc_[cellI] = 0;
Old   February 25, 2021, 12:15
Michael Alletto
Look for the member function value()
openfoam
Boundary condition for a baffle in the Laplacian mesh motion solver tecmul OpenFOAM Running, Solving & CFD 0 May 11, 2020 23:10
How can I use solution from one simulation as initial condition on a remote solver? Dano62 CFX 0 October 21, 2015 18:45
adding Porous media to lagrangian Solver kalyan OpenFOAM Programming & Development 0 September 19, 2014 08:41
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
