error: ‘class Foam::isoAdvection’ has no member named ‘getRhoCpPhi’
Old   February 15, 2021, 08:06
Default error: ‘class Foam::isoAdvection’ has no member named ‘getRhoCpPhi’
Kumar Pushpak
khool_chelsea is on a distinguished road
I am trying to add energy equation in the solver InterIsoFoam. The in-built solver calculates rhoPhi as
rhoPhi = advector.getRhoPhi(rho1f, rho2f);
Since Energy equation is also added so i am trying to calculate rhoCpPhi as
rhoCpPhi = advector.getRhoCpPhi(rho1f, rho2f);
I have defined getRhoCpPhi in isoAdvector.H as:
// Return Heat flux
        tmp<surfaceScalarField> getRhoCpPhi
                const dimensionedScalar rho1,
                const dimensionedScalar rho2,
            const dimensionedScalar cp1,
                const dimensionedScalar cp2
            ) const
                return tmp<surfaceScalarField>
                    new surfaceScalarField
                        "rhoCpPhi",
                        (rho1*cp1 - rho2*cp2)*dVf_/mesh_.time().deltaT() + cp2*rho2*phi_
The library gets compiled but while compiling the solver, it displays:
In file included from alphaEqnSubCycle.H:51:0,
from pinterIsoFoam2.C:147:
alphaEqn.H: In function ‘int main(int, char**)’:
alphaEqn.H:23:21: error: ‘class Foam::isoAdvection’ has no member named ‘getRhoCpPhi’; did you mean ‘getRhoPhi’?
getRhoPhi
In file included from alphaEqnSubCycle.H:59:0,
getRhoPhi
/home/administrator/OpenFOAM/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/pinterIsoFoam2.o' failed
What might i be missing?
khool_chelsea is offline   Reply With Quote
interisofoam, isoadvector
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
