High negative pressure in incompressible flow simulation
Old   February 4, 2021, 15:40
Default High negative pressure in incompressible flow simulation
HH
user_HH is on a distinguished road
Good afternoon!
I have been running an unsteady incompressible flow case with SRF using a solver which is a modified version of pimpleFOAM (no changes to pEqn and UrelEqn) in OF v18.06. I used fixedValue pressure BC at inlet and outlet which are set to 0 (i.e. gauge pressure assuming 1.013 bar atm pressure).
I have been experiencing high negative pressures. I understand that in incompressible flow what matters is the grad of pressure and not the pressure value itself and the pressure reported by OF is kinematic pressure.
When I convert -700m2/s2 to absolute pressure (-700m2/s2*850kg/m3 (fluid density)+101325Pa (reference pressure))= -493675 Pa = -4.9bar. The absolute pressure comes to be negative, which should not be the case.
The velocity values (absolute and relative) seems to be reasonable.
Can anyone help me understand how to treat the pressure and what I may be doing wrong while calculating absolute pressure?
I have read all possible forums with respect to pressure in incompressible flow but I am out of ideas to see how to avoid negative pressure value.
Thank you in advance.
Best,
Hiral
user_HH is offline   Reply With Quote
Pressure driven flow through a valve: pressure BCs clarification Coraz94 FLUENT 1 December 17, 2020 06:37
Flow from low to high pressure Lookid Main CFD Forum 4 November 16, 2017 12:41
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure vinguva OpenFOAM Running, Solving & CFD 2 March 8, 2016 00:46
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
