No such file or directory: #include <features.h> |
December 29, 2020, 17:59 |
#1 | |
Rep Power: 5 |
I want to write a simple code in OpenFoam Code:
// A hello world program in C++ #include<iostream> using namespace std; int main() { cout << "Hello World!"; return 0; } Code:
g++ hello_world.cpp Quote:
Best regards. |
December 30, 2020, 17:04 |
Rep Power: 14 |
This is a little odd. Did you list the WHOLE of your code?
December 30, 2020, 18:02 |
Rep Power: 5 |
I shared the whole code. There is not another part.
January 1, 2021, 07:26 |
Rep Power: 14 |
Ok - that IS wierd, but a quick google search shows that it's a fairly common problem that's not associated with OpenFOAM - there's something wrong/incomplete with your g++ installation, see e.g.:
https://stackoverflow.com/questions/...ow-do-i-get-it Try checking/reinstalling your g++ installation. Good luck. |
January 1, 2021, 10:11 |
Rep Power: 5 |
Thanks,
Your suggestion helped to solve the problem. I implemented Code:
sudo apt-get install g++-multilib |
January 1, 2021, 13:37 |
Rep Power: 14 |
Great job - well done!
c++, coding, openfoam 1712 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
OpenFoam install script Error during paraFoam installation | SePe | OpenFOAM Installation | 10 | June 19, 2010 16:15 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
