rhoPimpleFoam Initial Density
Old   December 22, 2020, 08:03
Default rhoPimpleFoam Initial Density
kamakura is on a distinguished road
Dear Foamers,
I am trying to calculate a compressible fluid using rhoPimpleFoam(OpenFOAM1806).
My question is the calculation of density.
I use the ideal gas law (perfect Gas) to calculate density.
Do you know how the density at the start of the calculation is calculated?
It was found that the density was calculated from the pressure, gas constant, and temperature, and the initial value of the pressure was read in createfields.H.
I didn't know how the initial temperature values ​​were read.
Thanks in advance.
kamakura is offline   Reply With Quote
Old   December 22, 2020, 16:36
Michael Alletto
mAlletto will become famous soon enough
https://cfd.direct/openfoam/user-gui...hermophysical/
See equation of state
mAlletto is offline   Reply With Quote
Old   December 23, 2020, 00:46
Dear mAlletto,
Thank you for your reply. I apply perfectGas to calculate the density.
I understand that the density field is calculated using pressure field, temperature field, and gas constant at any time step (after starting time loop).
I can not understand that how the density is calculated BEFORE starting time loop.
In the createfields.H, pressure is initialized, then, density is initialized.
But where Temperature is initialized?
I apologize for the difficulty in reading in my poor English.
Old   December 23, 2020, 03:22
Michael Alletto
The temperature is calculated in the thermopackage from the energy.
https://caefn.com/openfoam/temperature-calculation
Old   December 23, 2020, 03:44
Dear mAlletto,
Thanks to the link you pasted, I understand the existence of a function that transforms energy into temperature.
At first of the calculation, temperature is initialized using the function.
Thank you for your kindness.
compressible, density, rhopimplefoam
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
