Nikhil
Rep Power: 6 ![]() |
Hallo Foamers,
I have a small doudt. In UEqn.H, in solvers where momentum predictor setting exists in pimple loop. If momentum predictor is set to no then the Right-hand side of the momentum equation is not solved (skipped because of if loop). But, I dont understand, in any case, we need to solve whole momentum equation to get U right? . Why we skip gravity and dp term ? what does this mean ![]() Code:
tmp<fvVectorMatrix> tUEqn ( fvm::ddt(rho, U) + fvm::div(phi, U) + MRF.DDt(rho, U) + turbulence->divDevTau(U) == fvOptions(rho, U) ); fvVectorMatrix& UEqn = tUEqn.ref(); UEqn.relax(); fvOptions.constrain(UEqn); // In here if (pimple.momentumPredictor()) { solve ( UEqn == fvc::reconstruct ( ( - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) )*mesh.magSf() ) ); fvOptions.correct(U); K = 0.5*magSqr(U); } |
Cyprien
Rep Power: 18 ![]() |
Dear Nikhil,
When you turn off momentumPrediction, you do no solve the momentum equation. If you look at the predictor-corrector solution algorithms used in CFD (PISO, SIMPLE, PIMPLE...), basically you do the following sequence: - Discretize the momentum equation and form a matrix for U (optionnaly inverse this matrix to have a first guess of U) - Form a matrix for p. This matrix depends on the coefficients of the matrix for U. Inverse the matrix for p. - Correct the value of U point-wised based on the updated pressure field. - Iterate until you converge. - March in time So, when you turn off momentumPrediction, you do update the coefficients in the matrix for U, but you do not inverse this matrix. Cheers, Cyprien
www.cypriensoulaine.com/openfoam |
Nikhil
Hallo Cyprien,
Thanks for the explanation. Yah! now it's crystal clear. cheers, nick. |
momentum equation, piso, ueqn.h |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
Spray total droplet momentum calculation help | tarnsharma | AVL FIRE | 0 | July 19, 2012 08:17 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
