Time dependent gradient boundary condition
Old   November 26, 2020, 09:52
Default Time dependent gradient boundary condition
jeroendemto is on a distinguished road
Hello everyone!
As the title states I'm trying to imply a time dependant gradient as a boundary condition. You can find the formula I'm trying to implement on the boundary as attachment. The method I tried is using uniformFixedGradient and use an uniform value which is a polynomial. This looks as follows:
    inlet
        type        uniformFixedGradient;
        uniformValue polynomial ( (-2.82*T[0] 0.5));
I know the meshid of the cell I want to imply the boundary condition is the first cell, hence the T[0].
However I get the following error code
keyword uniformGradient is undefined in dictionary "/0/T.boundaryField.inlet"
file: /0/T.boundaryField.inlet from line 25 to line 26.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 570.
FOAM exiting
It seems like I'm using the wrong type, but I don't know which other type I have to use.
Kind regards,
Jeroen
jeroendemto is offline   Reply With Quote
Old   November 27, 2020, 09:36
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Jeroen,
Personally I have not used this boundary condition, but the error message that you get is quite clear:
Which is correct as you have specified:
So if you change the uniformValue to a uniformGradient at least this error should go away.
Best Regards,
Tom
tomf is offline   Reply With Quote
Old   November 30, 2020, 01:37
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
Originally Posted by jeroendemto View Post
Hello everyone!
    inlet
FOAM exiting
Kind regards,
Jeroen
Hi Jeroen,
You can use groovyBC boundary conditions, which comes with swak4Foam, for your case.
Shakil
ahmmedshakil is offline   Reply With Quote
[swak4Foam] Time and Location Dependent Boundary Condition uyelken OpenFOAM Community Contributions 0 January 2, 2020 09:22
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
