How to store a p matrix in Matrix Market (.mtx) format?
Old   November 19, 2020, 11:17
Default How to store a p matrix in Matrix Market (.mtx) format?
Klaus
klausb will become famous soon enough
I need a pressure "p" matrix of an external flow case with 1-2 million cells in Matrix Market (.mtx) format for solver development.
Is there a tool that allows to store a pressure matrix of a particular timestep in the Matrix Market (.mtx) format?
Klaus
klausb is offline   Reply With Quote
Old   November 19, 2020, 16:53
Santiago Lopez Castano
Santiago is on a distinguished road
Klaus
no idea what matrix market is, but you can convert the csr matrix produced by fvMatrix<> to the simpleMatrix<> class. That class follows the classical indicial i,j form
Santiago is offline   Reply With Quote
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 12:16
[Discretizer] Installing Discretizer umassche OpenFOAM Community Contributions 26 January 25, 2017 06:33
[General] Paraview data format conversion from vtk to parallel prog data format. odho ParaView 0 September 20, 2016 08:01
extracting velocity field from 0/U file into matrix format eaglemckenna OpenFOAM Post-Processing 3 November 5, 2014 12:29
Parallel algorithm to convert dense to sparse (CRS) matrix format Italo Main CFD Forum 0 December 19, 2011 04:01
