Viv dynamicmesh
Old   November 16, 2020, 08:05
Default Viv dynamicmesh
ROIN bin
Beingzzz is on a distinguished road
Dear all,I was planning to do some cylinder bypassing in the pipeline and first planned the 2D case with reference to wingmotion in pimpleFoam, but after a while I get the following error (forces forces: not including porosity effects)What changes should I make to improve this situation or have a better idea thanks.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ("libsixDoFRigidBodyMotion.so");
motionSolver sixDoFRigidBodyMotion;
patches (scylinder);
innerDistance 10;
outerDistance 8;
mass 1;
centreOfMass (0 16.125 0.5);
momentOfInertia (1.958864357 3.920839234 2.057121362);
g (0 -9.81 0);
rho rhoInf;
rhoInf 1;
report on;
solver
type symplectic;
constraints
yAxis
sixDoFRigidBodyMotionConstraint axis;
axis (0 1 0);
restraints
axialSpring
sixDoFRigidBodyMotionRestraint linearAxialAngularSpring;
axis (0 1 0);
stiffness 700;
damping 0.5;
Beingzzz is offline   Reply With Quote
Old   November 16, 2020, 17:18
Krapf is on a distinguished road
This is not an error message. Take a look at the last few lines of the log file.
Krapf is offline   Reply With Quote
Old   November 17, 2020, 00:00
ROIN bin
Thanks, you're right. This is the last picture in question. I then modified the mesh density, the mesh motion parameters of the moving mesh and the pressure solver in fvsolution, but it only advanced the calculation a little bit, and then the equation collapsed. Is it because of the wall, there is a size limit on the upload file and I can't show the full case. Thanks again.
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 1.92691e+06
Specified mass inflow   : 0
Specified mass outflow  : 56904.1
Adjustable mass outflow : 2.10588e-14
    From function bool Foam::adjustPhi(Foam::surfaceScalarField&, const volVectorField&, Foam::volScalarField&)
    in file cfdTools/general/adjustPhi/adjustPhi.C at line 107.
Old   November 17, 2020, 02:49
I'm not sure if I can help you with that. What are your pressure/velocity boundary conditions at inlet and outlet? Does it run without this error if you deactivate the dynamic mesh?
Old   November 17, 2020, 03:13
ROIN bin
The same conditions I've run smoothly using icoFoam, I've posted the other setup files later. I have a feeling there is something wrong with the parameter settings. Anyway thank you very much.
fvsolusion
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
     "pcorr.*"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0;
    p
        $pcorr;
        tolerance        1e-7;
        relTol           0.01;
    pFinal
        $p;
        tolerance        1e-7;
        relTol           0;
    U
        tolerance       1e-05;
        relTol          0;
	UFinal
        $U;
        tolerance       1e-05;
        relTol          0;
	"(k|nut|omega)"
        tolerance       1e-06;
        relTol          0.01;
    "(k|nut|omega)Final"
        $U;
        tolerance       1e-06;
        relTol          0;
	cellDisplacement
        tolerance       1e-06;
        relTol          0.01;
PIMPLE
    correctPhi          yes;
    nOuterCorrectors    2;
    nCorrectors         1;
    nNonOrthogonalCorrectors 0;
pRefCell 1001;
pRefValue 0;
relaxationFactors
    fields
        p               0.3;
    equations
        "(U|k|omega)"   0.7;
        "(U|k|omega)Final" 1.0;
cache
    grad(U);
fvschemes
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
	grad(U)         Gauss linear;
divSchemes
    default         none;
	div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,omega)  Gauss limitedLinear 1;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear limited corrected 0.5;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
Old   November 18, 2020, 11:39
Michael Alletto
mAlletto will become famous soon enough
There is tutorial available which computes 2d vortex induced vibration (viv) of a circular cylinder in laminar flow:
https://wiki.openfoam.com/Vortex_ind...ichael_Alletto
This may be helpful
mAlletto is offline   Reply With Quote
Old   February 13, 2022, 04:02
Default Phase Angle Calculation
zink
ansab_sindhu is on a distinguished road
Your tutorial is quite helpful, How can we calculate phase angle in python?
This may be helpful
ansab_sindhu is offline   Reply With Quote
Old   February 13, 2022, 09:16
Michael Alletto
Which phase angle do you mean
Old   February 13, 2022, 14:54
zink
phase angle between the lift force vector and cylinder motion displacement.
(for 2Dof Motion). I heard one can calculate using Hilbert transform but I still need to learn.
Old   February 14, 2022, 16:31
Michael Alletto
Did you try to use the dot product to calculate the phase angle
dynamicmesh error
Simulating vortex induced vibrations (VIV) through UDF diggee FLUENT 0 May 30, 2018 08:25
External management of solid motion (using dynamicmesh) maxou1993 Main CFD Forum 0 July 28, 2015 12:37
Which transition model for VIV on risers? jordan.c Main CFD Forum 0 May 5, 2015 04:34
Vortex Induced Vibration (VIV) modelling Kwong FLUENT 1 December 1, 2009 14:08
VIV Sham FLUENT 0 December 14, 2006 23:13
