PimpleFoam Time Varying Ubar
Old   November 5, 2020, 13:40
Default PimpleFoam Time Varying Ubar
Will M
willscottmatt is on a distinguished road
Hi all,
I am trying to increase Ubar with time so that I may have an unsteady flow. This has been confusing me for some time now.
I am using the channel395 case and have looked into using a codedSource to change Ubar, but I couldn't get that to work so if someone has some tips on this please lend a hand.
I have also tried adding a term to the UEqn, from which I had a little success because it did increase something, but that something was the pressure gradient as the line,
fvOptions.constrain(UEqn);
is making things quite difficult by cancelling out my new term by increasing the pressure gradient in the opposite direction to hit the target Ubar that is set in fvOptions.
So I thought it would be a good idea to create my own constrain class that doesn't want to ruin my hard work. It is clear to me that this is probably in fact not the most ideal way to get what I want.
If anyone could show me the best way of doing this whether it be through a codedSource in fvOptions, or adding my own time varying momentum term to UEqn that would be most appreciated.
willscottmatt is offline   Reply With Quote
Old   March 7, 2022, 02:45
chandra shekhar pant
chandra shekhar pant is on a distinguished road
I am also trying a similar thing, have you been able to figure this out, to add sinusoidal/time varying ubar in fvoptions? If yes, then please help me, thanks in advance.
chandra shekhar pant is offline   Reply With Quote
Old   August 20, 2022, 02:44
M. Nasr
M. Nasr is on a distinguished road
Have you managed to apply sinusoidal/time varying ubar in fvoptions?
M. Nasr is offline   Reply With Quote
Old   August 20, 2022, 22:52
Unfortunately no, I am still not been able to figure this out.
Old   March 22, 2023, 05:43
xu
hhu_xpc is on a distinguished road
add sinusoidal/time varying ubar in fvoptions is finish?If yes, please help me,thanks in advance
hhu_xpc is offline   Reply With Quote
Old   March 23, 2023, 10:22
Hi, instead to directly implement ubar, I tried to do the following:
Could pressure gradient be modelled as "vectorCodedSource" in fvoptions at inlet
channel395, classes, fvoptions, meanvelocityforce, ubar
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
