Issues with OpenFOAM on an HPC with GCC+MVAPICH2.
Old   October 18, 2020, 16:48
Default Issues with OpenFOAM on an HPC with GCC+MVAPICH2.
Prakriti
Prakriti is on a distinguished road
Hi all,
I compiled OpenFOAM-7 on an HPC that has GNU/GCC compilers but not OpenMPI. I had initially compiled it with ICC/IntelMPI using the pointers provided in this post: Compilation Error with OpenFOAM-5.x using Intel Compilers
However, with that combination (Icc+IMPI), I started running into errors like the simulations stopping on random time steps.
So I tried to reinstall OpenFOAM with GCC+OpenMPI but compiling OpenMPI on my local allocation on the HPC. I did this for OpenFOAM-8 but could not get it to compile for OpenFOAM-7 (unrecognized MPI).
Finally, I tried to compile OpenFOAM-7 with GCC+MVAPICH2 (already present on the HPC) and OpenFOAM compiled without errors.
However, when I ran my simulations last night, they randomly stopped at random time steps with error messages:
1) 1st kind.
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: Iteration 1
DILUPBiCGStab: Solving for Ux, Initial residual = 2.38762e-08, Final residual = 1.04175e-16, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 2.38762e-08, Final residual = 1.04175e-16, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 2.38762e-08, Final residual = 1.04175e-16, No Iterations 1
DILUPBiCGStab: Solving for O2, Initial residual = 0.000388346, Final residual = 3.19766e-18, No Iterations 1
DILUPBiCGStab: Solving for He, Initial residual = 8.82241e-17, Final residual = 8.82241e-17, No Iterations 0
[27] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[27] #1 Foam::sigFpe::sigHandler(int) at ??:?
[27] #2 ? in "/lib64/libc.so.6"
[27] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[27] #4 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[27] #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[27] #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[27] #7 Foam::fvMatrix<double>::solve() at ??:?
[27] #8 ? at ??:?
[27] #9 __libc_start_main in "/lib64/libc.so.6"
[27] #10 ? at ??:?
[c188-051.frontera.tacc.utexas.edu:mpi_rank_27][error_sighandler] Caught error: Floating point exception (signal 8)
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 155593 RUNNING AT c188-051
= EXIT CODE: 8
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Floating point exception (signal 8)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
2) 2nd kind.
PIMPLE: Iteration 1
DILUPBiCGStab: Solving for Ux, Initial residual = 0.00180794, Final residual = 1.78746e-10, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.0026315, Final residual = 2.52956e-10, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 0.0202497, Final residual = 1.56385e-09, No Iterations 1
DILUPBiCGStab: Solving for FSD, Initial residual = 3.02246e-05, Final residual = 4.04184e-11, No Iterations 1
DILUPBiCGStab: Solving for O2, Initial residual = 6.59176e-06, Final residual = 5.15039e-09, No Iterations 1
DILUPBiCGStab: Solving for H2O, Initial residual = 6.63204e-06, Final residual = 5.16573e-09, No Iterations 1
DILUPBiCGStab: Solving for CH4, Initial residual = 2.88619e-06, Final residual = 9.02189e-09, No Iterations 1
DILUPBiCGStab: Solving for CO2, Initial residual = 6.63204e-06, Final residual = 5.16573e-09, No Iterations 1
Radiation solver iter: 0
GAMG: Solving for ILambda_0_0, Initial residual = 0.0494203, Final residual = 0.00193215, No Iterations 1
GAMG: Solving for ILambda_1_0, Initial residual = 0.0356651, Final residual = 0.00106093, No Iterations 1
[0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 ? in "/lib64/libc.so.6"
[0] #3 MPIR_SUM in "/opt/apps/gcc9_1/mvapich2-x/2.3/lib64/libmpi.so.12"
[0] #4 MPIR_Allreduce_socket_aware_two_level_MV2 in "/opt/apps/gcc9_1/mvapich2-x/2.3/lib64/libmpi.so.12"
[0] #5 MPIR_Allreduce_index_tuned_intra_MV2 in "/opt/apps/gcc9_1/mvapich2-x/2.3/lib64/libmpi.so.12"
[0] #6 MPIR_Allreduce_impl in "/opt/apps/gcc9_1/mvapich2-x/2.3/lib64/libmpi.so.12"
[0] #7 MPI_Allreduce in "/opt/apps/gcc9_1/mvapich2-x/2.3/lib64/libmpi.so.12"
[0] #8 void Foam::allReduce<double, Foam::sumOp<double> >(double&, int, int, int, Foam::sumOp<double> const&, int, int) at ??:?
[0] #9 Foam::reduce(double&, Foam::sumOp<double> const&, int, int) at ??:?
[0] #10 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #11 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const at ??:?
[0] #12 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
[0] #13 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #14 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[0] #15 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[0] #16 Foam::fvMatrix<double>::solve(Foam::word const&) at ??:?
[0] #17 Foam::radiationModels::radiativeIntensityRay::corr ect() at ??:?
[0] #18 Foam::radiationModels::fvDOM::calculate() at ??:?
[0] #19 Foam::radiationModel::correct() at ??:?
[0] #20 ? at ??:?
[0] #21 __libc_start_main in "/lib64/libc.so.6"
[0] #22 ? at ??:?
[c168-114.frontera.tacc.utexas.edu:mpi_rank_0][error_sighandler] Caught error: Floating point exception (signal 8)
= PID 225163 RUNNING AT c168-114
= EXIT CODE: 8
Could these be attributable to an OpenFOAM compilation issue? I'm stuck, please help.
Also, I would like some help with compiling OpenMPI locally on my HPC user allocation, to be able to compile OpenFOAM with it. Please help.
Prakriti is offline   Reply With Quote
cluster setup, compilation error, openfoam-7, openmpi 4, wyldkat
Issues with mpirun in HPC lebc OpenFOAM Running, Solving & CFD 5 April 22, 2019 18:20
[OpenFOAM.org] Problems with installing openfoam 5.0 on HPC Cluster sjlouie91 OpenFOAM Installation 4 January 20, 2019 16:35
OpenFoam in docker (gcc 6) vs. OpenFoam natively compiled (gcc 8.1.1) Anouk OpenFOAM Running, Solving & CFD 0 September 17, 2018 09:02
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 06:51
