Access species thermo functions from chtMultiRegionFoam bouandray condition
Old   October 16, 2020, 13:13
Default Access species thermo functions from chtMultiRegionFoam bouandray condition
Joachim Herb
jherb is on a distinguished road
I am trying to access the species thermo functions, especially HE and Cp/Cv, from within a boundary condition for chtMultiRegionFoam.
The starting point is this boundary condition implemented in OpenFOAM-8: https://github.com/OpenFOAM/OpenFOAM...hScalarField.C
Depending, on which side of the wall the solver is, there is either a fluid or a solid thermo model.
For the fluid side, I was able to access the methods using this (pseudo) code:
    if (mesh.foundObject<rhoReactionThermo>(basicThermo::dictName))
        const rhoReactionThermo& nbrThermo =
            mesh.lookupObject<rhoReactionThermo>(basicThermo::dictName);
        const basicSpecieMixture& composition = nbrThermo.composition();
        const PtrList<volScalarField>& Y = composition.Y();
//        Info<<"Y.size: " << Y.size() << endl;
        forAll(TList, faceI) {
            scalar he = 0;
            scalar Cpv = 0;
            if (Y.size() > 0) {
                forAll(Y, componentI) {
                    scalar Yi = Y[componentI].boundaryField()[samplePatchi][faceI];
                    he += Yi*composition.HE(
                        componentI, nbrPPatch[faceI], TList[faceI]
                    Cpv += Yi*composition.Cp(
            else
                scalar Yi = 1;
                    0, nbrPPatch[faceI], TList[faceI]
One thing, I do not really understand is the case, where I have a pureMixture and then, Y() returns a list of length zero. Nevertheless, if I use the index 0 for the access of the methods, it seems to work. Why?
On the solid side, I was not able to get hold on any "composition". I tried something like this:
        const solidThermo& nbrThermo =
            nbrMesh.lookupObject<solidThermo>(basicThermo::dictName);
but solidThermo does not have a composition() method. Looking in the source code, there is a class heSolidThermo using the methods HE and Cp, but I was not able to use it, because I did not find correct template arguments to create a reference and assigning something inside the objectRegistry to this reference.
Is there a way to access this compositon/mixture methods of a solid?
Thank you for any help
Joachim
jherb is offline   Reply With Quote
Old   October 16, 2020, 17:00
clapointe is on a distinguished road
I've been working through similar issues recently, I think. I'm not sure about accessing composition/etc for solidThermo, but what I've done is use a solid reaction thermo... you could use it without reactions, and it should provide a means to use a multi-component (homogenous) mixture if desired. Then you can access using something like :
solidReactionThermo& solidThermo = solidThermos[i];
basicSpecieMixture& composition = solidThermo.composition();
PtrList<volScalarField>& Ys = composition.Y();
This assumes that you open to using a version different from OpenFOAM 8 (for which the solid reactions are in some phase of restructuring). I suppose another option is to port solidReactionThermo from 7 to 8...
Caelan
clapointe is offline   Reply With Quote
Old   October 16, 2020, 17:52
Joachim Herb
Thank you for your answer. Unfortunately, I would like to do this in OpenFOAM-8. And solidReactionThermo was completely removed in this version.
Species Transport Boundary Condition Nishant_Sharma FLUENT 2 June 1, 2018 03:16
controlDict dynamic functions for chtMultiRegionFoam Mhmnabil OpenFOAM Running, Solving & CFD 0 October 25, 2017 15:22
Define functions for Boundary Condition of Thermal Problems in Ansys cyrusIII ANSYS 0 October 16, 2016 18:50
JANAF thermo, species with different Tcommon adhiraj OpenFOAM 4 March 10, 2014 10:51
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
