externalCoupledTemperature for incompressible?
Old   September 30, 2020, 14:07
Smile externalCoupledTemperature for incompressible?
sibo
sibo is on a distinguished road
Hi Foamers,
There is an boundary condition called externalCoupledTemperature which is used to couple OF solves to other CFD codes. However, it can only be used in compressible solver for now. The reason can be found in the following code. Basically, this BC needs 'he' and 'alpha', which can only be accessed in thermo class in compressible solvers. Since the incompressible solvers solve temperature separately from P/U, it only has this transport class.
if (db().foundObject<cmpTurbModelType>(turbName))
        const cmpTurbModelType& turbModel =
            db().lookupObject<cmpTurbModelType>(turbName);
        const basicThermo& thermo = turbModel.transport();
        const fvPatchScalarField& hep = thermo.he().boundaryField()[patchi];
        qDot = turbModel.alphaEff(patchi)*hep.snGrad();
    else if (db().foundObject<basicThermo>(thermoName))
        const basicThermo& thermo = db().lookupObject<basicThermo>(thermoName);
        qDot = thermo.alpha().boundaryField()[patchi]*hep.snGrad();
    else
        FatalErrorInFunction
            << "Condition requires either compressible turbulence and/or "
            << "thermo model to be available" << exit(FatalError);
    }if (db().foundObject<cmpTurbModelType>(turbName))
    else
Now I need to use it in incompressible solvers, I want to modify this boundary condition. But I'm not sure how to give it the 'he' and 'alpha' in an incompressible solver.
Any suggestion is welcome. Thanks in advance!
sibo is offline   Reply With Quote
Old   October 3, 2020, 11:32
Michael Alletto
mAlletto will become famous soon enough
Did you try to use a compressible solver but choosing a constant density and in the thermodynamic package. See https://cfd.direct/openfoam/user-gui...hermophysical/
mAlletto is offline   Reply With Quote
externalcoupled, incompressible, thermo
