September 24, 2020, 12:13 |
1D Stefan problem validation of new solver
Rep Power: 6 |
Hello everyone,
I developed a new evaporation solver based on some excellent solvers (interFoam, interPhaseChangeFoam and evapVOFHardt), and when I validated the 1D Stefan problem, the velocity field is not correct (see attached), and some key code can be found as follows: 1. Source terms in alphaEqn (the same as the source terms in interPhaseChangeFoam) // explicit source term volScalarField Su ( IOobject ( "Su", runTime.timeName(), mesh ), - dotM/rho1 ); //zeroField Sp; // implicit source term volScalarField Sp ( IOobject ( "Sp", runTime.timeName(), mesh ), fvc::div(phi) - dotM*(1.0/rho2-1.0/rho1) ); 2. UEqn with new source terms fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(rhoPhi, U) - fvm::Sp(fvc::ddt(rho) + fvc::div(rhoPhi), U) // new + MRF.DDt(rho, U) + turbulence->divDevRhoReff(rho, U) == fvOptions(rho, U) ); 3. TEqn Info << "Solve TEqn" << endl; { volScalarField k = alpha1*k1 + alpha2*k2; // one-field formulation volScalarField rhoCp = alpha1*rho1*cp1 + alpha2*rho2*cp2; // one-field formulation; rho:density; cp: specific heat capacity surfaceScalarField alphaPhi = (rhoPhi-phi*rho2)/(rho1-rho2); // hint: rhoPhi = alpha1*rho1*phi + (1-alpha1)*rho2*phi // rho1 must not be equal to rho2 surfaceScalarField rhoCpPhi = alphaPhi*(rho1*cp1-rho2*cp2)+phi*rho2*cp2; // rhoCpPhi = alpha1*rho1*cp1*phi + (1-alpha1)*rho2*cp2*phi fvScalarMatrix TEqn ( fvm::ddt(rhoCp,T) + fvm::div(rhoCpPhi,T) - fvm::laplacian(k,T) == fvm::Sp(fvc::ddt(rhoCp) + fvc::div(rhoCpPhi),T) // new source term 01 (Coupled to mass source term) + fvm::Sp(TEqnSou,T) - TEqnSou*Tsat // new source term 02 (cooling due to evaporation) ); TEqn.relax(); TEqn.solve(); Info<< "min/max(T) = " << min(T).value() << "; " << max(T).value() <<endl; } 4. pEqn fvScalarMatrix p_rghEqn ( fvm::laplacian(rAUf, p_rgh) == fvc::div(phi) - dotM*(scalar(1.0)/rho2 - scalar(1.0)/rho1) //new ); 5. source terms (modified from evapVOFHardt) volScalarField jLoc = (T-Tsat)/(Rint*hEvap); dotM = jLoc*magGradAlpha; forAll(alpha1.ref(),iCell) { if (magGradAlpha.ref()[iCell] > 0.0) { dotM[iCell] *= 1.0; // only set source terms in interface cells } else { dotM[iCell] *= 0.0; } } // the second term of the TEqn TEqnSou = -magGradAlpha/Rint; 6. main program #include "sourceTerms.H" evapRate = fvc::domainIntegrate(dotM); #include "TEqn.H" Info<< "Evaporation rate is = " << evapRate.value() << "kg/s at t = " << runTime.timeName() << "s" << endl; If anyone know how to fix the problem, it will be best, and if I have something wrong in my code, please let me know. Many thanks, Huihui |
February 8, 2021, 11:10 |
H.Ham
Rep Power: 7 |
You work on 1D twho-phase-flow probleme, , Me too, i work on 1D two-phase-flow but compressible configuration . I hope that you resolve your problem Please, I would like to know how you chose your discretizations (fvSchemes and fvSolution) for your problem ?? best regret, |
evaporation, vof |
Problem with validation of regionCouple solver | tladd | OpenFOAM Verification & Validation | 0 | May 22, 2014 19:09 |
Is there a problem in the Euler solver? | Combas | SU2 | 4 | March 28, 2014 16:48 |
[ANSYS Meshing] Problem with axisymmetric solver | Rasel | ANSYS Meshing & Geometry | 0 | June 20, 2012 05:35 |
mesh.update problem in a new FSI solver | ICL | OpenFOAM | 0 | October 8, 2011 15:16 |
patching problem unsteady solver | yellow-stuff | Main CFD Forum | 0 | September 25, 2009 02:26 |
