Contact angle for icoReactingMultiphaseInterfoam
Old   September 1, 2020, 16:49
Default Contact angle for icoReactingMultiphaseInterfoam
Jonathan Tran
jqtranus is on a distinguished road
I'm a beginner at C++, and coding in general (I'm a first year), so I'm struggling to figure this out. I've been attempting to add the contact angle model from multiphaseInterFoam into icoReactingMultiphaseInterFoam.
I'm trying to get the wall velocity by subtracting the surface velocity from the internal field velocity at the boundary.
// Calculated the component of the velocity parallel to the wall
                 vectorField Uwall
                     U().boundaryField()[patchi].patchInternalField()
                   - U().boundaryField()[patchi]
                 Uwall -= (AfHatPatch & Uwall)*AfHatPatch;
Where U() is this function:
Foam::tmp<Foam::volVectorField> Foam::phaseSystem::U() const
    auto tstf = tmp<volVectorField>::New
        IOobject
            "U",
            mesh_.time().timeName(),
            mesh_
        mesh_,
        dimensionedVector(dimVelocity, Zero)
    auto& stf = tstf.ref();
    forAllConstIters(phaseModels_, iter)
        stf += iter()() * iter()->U();
    return tstf;
My problem is that I get this error:
phaseSystem/phaseSystem.C:1189:26: error: ‘class Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >’ has no member named ‘boundaryField’
From what I can understand, I believe U() is returning the internal velocity field, so why can't I get the boundary field from it?
Thanks in advance.
jqtranus is offline   Reply With Quote
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 15:00
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 03:39
inaccurate contact angle capturing in high shear/viscousity flow chery1986 OpenFOAM Running, Solving & CFD 0 October 23, 2015 01:14
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
