objectRegistry error. Migrating a B.C. from 2.4 to 7.0 |
August 26, 2020, 21:29 |
Francisco T
Rep Power: 14 |
Im trying to implement a dynamic boundary condition.
Kistler contact angle. This has been done for 2.4 https://github.com/MahdiNabil/CFD-PC...Foam/Libraries Im trying to implement it on 7.0 Library and solver compiles well after a couple of edits. Im getting this error: --> FOAM FATAL ERROR: request for volScalarField muEffKistler from objectRegistry region0 failed available objects of type volScalarField are 7 ( interfaceProperties:K alpha.water p_rgh nu nu1 nu2 alpha.air ) I guess the way the muEffKistler is written in the objectRegistry has to be updated for this new OF7 version. I have found differences bewteen 2.4 and 7.0 in the way volScalarField alpha is declared in createFields.H, older version: volScalarField alpha1 ( IOobject ...etc newer: volScalarField& alpha1(mixture.alpha1()); I have tried to use older declaration way in both alpha & muEff withouth success.. any clue? thanks for your time. |
June 10, 2021, 22:31 |
XinZhou
Rep Power: 8 |
Hi frantov, I have the same problem in openfoam-v2006,"request for volScalarField muEffKistler from objectRegistry region0 failed", Have you solve this problem? Could you please give me some advice.
July 30, 2021, 00:32 |
A. Min
Rep Power: 12 |
Hi guys,
I have the same problem in OpenFOAM-7, "request for volScalarField muEffKistler from objectRegistry region0 failed". If you found the solution, inform me, please. |
July 11, 2023, 04:37 |
Dynamic contact angle implementation
Hi frantov,
Are you now able to successfully implement the Dynamic Contact Angle model in InterFOAM? Best regards |
September 25, 2023, 07:14 |
Rep Power: 3 |
I am also facing this issue.
mueffkistler, object registry |
Question regarding objectRegistry and related subjects. | granzer | OpenFOAM | 0 | March 21, 2020 13:01 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 11:05 |
complex eigenvalues detected for tensor | thegauravonline | OpenFOAM Pre-Processing | 3 | January 14, 2017 05:18 |
flapping console "inverted" on icoFsiElasticNonLinULSolidFoam: FPE | thegauravonline | OpenFOAM Running, Solving & CFD | 3 | May 9, 2016 05:13 |
