Change actuationDiskSource from circle to rectangle |
August 19, 2020, 16:02 |
Tom Waits
Rep Power: 8 |
Hi All,
Where in the source code for actuationDiskSource is the diskArea () used to select cells within a circle? Even when topoSetDict is set to select cells within a bounding box, the resultant area is still circular. Many thanks in advance, Tom Waits Last edited by TomWaits; August 20, 2020 at 16:57. |
August 24, 2020, 17:37 |
Luis Eduardo
Rep Power: 15 |
Hi Tom,
The diskArea is an input for calculating the Thrust force, it is not used to select the cells or to define a region. The cell selection is defined in topoSetDict, but the area normal to the velocity will depend on your mesh, it will not necessarily be the same value as the diskArea. Best Regards, Luis |
No density change - rhoSimplecFoam | krapic | OpenFOAM | 1 | November 29, 2014 19:39 |
Subtraction of a circle from a rectangle,Gambit | engahmed | ANSYS Meshing & Geometry | 2 | May 17, 2010 02:08 |
[Other] Defining a circle within a rectangle domain | amscosta | OpenFOAM Meshing & Mesh Conversion | 1 | August 14, 2009 16:03 |
Find perpendicular intersection bet. pt & circle | zonexo | Main CFD Forum | 3 | July 27, 2007 09:53 |
How to mesh a circle by Gambit? | Zhengcai Ye | FLUENT | 5 | March 24, 2006 02:04 |
