How dependency file is generated in OpenFOAM
Old   August 18, 2020, 07:22
Post How dependency file is generated in OpenFOAM
saurabh
kavi.saurabh is on a distinguished road
Hi all.
I wanted to know, how OpenFoam selects the .C or .H files while generating dependency (.dep) for any source file.
I am asking this as i have added some .cpp files which i want to be in the dependency list in the same way as .H and .C files are added. I have just started working on OpenFOAM and very new to its code structure. It would be helpful if some info is available regarding this.
Thanks and Regards,
kavi.saurabh is offline   Reply With Quote
Old   August 18, 2020, 16:31
Domenico Lahaye
dlahaye is on a distinguished road
Often a file Make/files exists. The files Make/files and Make/options are used by wmake (a shell around make, see e.g. https://en.wikipedia.org/wiki/Make_(software) ) to manage the compilation.
dlahaye is offline   Reply With Quote
Old   September 6, 2020, 04:20
Rahul Vadrabade
Rvadrabade is on a distinguished road
Leave it to wmake to build dependency list.
Add as many .C files in Make/files (file name is EXE=) and all includes (EXE_INC) with library(EXE_LIBS) to be linked in Make/options.
I hope you are well aware of https://cfd.direct/openfoam/user-gui...-applications/
Rvadrabade is offline   Reply With Quote
community contribution, developers, openfoam
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
