renumberMesh_porosity_rhoReactingBuoyantFoam_editi ng_solver |
August 17, 2020, 18:34 |
Nikhil
Rep Power: 6 |
Hallo Foamers,
I want to add porous capability to rhoReactingBuoyantFoam, for that by taking rhoPorousSimpleFoam as reference, I did the respective changes in UEqn.H, pEqn.H and .C file. I tested the solver with a known case, and everything runs good. But, when I use renumberMesh and run the solver, then it throws a tmp deallocated error as follows. Code:
Starting time loop Courant Number mean: 0 max: 0 deltaT = 1.2e-10 Time = 1.2e-10 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for C3H8, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 5.23194e-05, Final residual = 1.20767e-20, No Iterations 1 min/max(T) = 293, 293 --> FOAM FATAL ERROR: tmp<N4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEE> deallocated From function const T& Foam::tmp<T>::operator()() const [with T = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>] in file /opt/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/tmpI.H at line 278. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >::operator()() const in "/disk/nmittapa/FOAM_USER_APPBIN/rhoPorousBuoyantFoam" #3 ? in "/disk/nmittapa/FOAM_USER_APPBIN/rhoPorousBuoyantFoam" #4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #5 ? in "/disk/nick/FOAM_USER_APPBIN/rhoPorousBuoyantFoam" Aborted UEqn.H Code:
MRF.correctBoundaryVelocity(U); fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(phi, U) + MRF.DDt(rho, U) + turbulence->divDevRhoReff(U) == fvOptions(rho, U) ); UEqn.relax(); tmp<volScalarField> trAU; tmp<volTensorField> trTU; if (pressureImplicitPorosity) { tmp<volTensorField> tTU = tensor(I)*UEqn.A(); pZones.addResistance(UEqn, tTU.ref()); trTU = inv(tTU()); trTU.ref().rename("rAU"); fvOptions.constrain(UEqn); volVectorField gradp(fvc::reconstruct ( ( - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) )*mesh.magSf() ) ); for (int UCorr=0; UCorr<nUCorr; UCorr++) { U = trTU() & (UEqn.H() - gradp); } U.correctBoundaryConditions(); fvOptions.correct(U); K = 0.5*magSqr(U); } else { pZones.addResistance(UEqn); fvOptions.constrain(UEqn); if(pimple.momentumPredictor()) { solve ( UEqn == fvc::reconstruct ( ( - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) )*mesh.magSf() ) ); fvOptions.correct(U); K = 0.5*magSqr(U); trAU = 1.0/UEqn.A(); trAU.ref().rename("rAU"); } } Code:
rho = thermo.rho(); const volScalarField psip0(psi*p); volScalarField rAU(1.0/UEqn.A()); surfaceScalarField rhorAUf("rhorAUf", fvc::interpolate(rho*rAU)); tmp<volVectorField> tHbyA; if (pressureImplicitPorosity) { tHbyA = constrainHbyA(trTU()&UEqn.H(), U, p); } else { tHbyA = constrainHbyA(trAU()*UEqn.H(), U, p); } volVectorField& HbyA = tHbyA.ref(); surfaceScalarField phig(-rhorAUf*ghf*fvc::snGrad(rho)*mesh.magSf()); surfaceScalarField phiHbyA ( "phiHbyA", ( fvc::flux(rho*HbyA) + MRF.zeroFilter(rhorAUf*fvc::ddtCorr(rho, U, phi)) ) + phig ); MRF.makeRelative(fvc::interpolate(rho), phiHbyA); constrainPressure(p_rgh, rho, U, phiHbyA, rhorAUf, MRF); fvScalarMatrix p_rghDDtEqn ( fvc::ddt(rho) + psi*correction(fvm::ddt(p_rgh)) + fvc::div(phiHbyA) == fvOptions(psi, p_rgh, rho.name()) ); while (pimple.correctNonOrthogonal()) { tmp<fvScalarMatrix> tpEqn; if (pressureImplicitPorosity) { tpEqn = ( p_rghDDtEqn - fvm::laplacian(rho*trTU(), p_rgh) ); } else { tpEqn = ( p_rghDDtEqn -fvm::laplacian(rho*trAU(), p_rgh) ); } fvScalarMatrix& p_rghEqn = tpEqn.ref(); p_rghEqn.solve(); if (pimple.finalNonOrthogonalIter()) { phi = phiHbyA + p_rghEqn.flux(); p_rgh.relax(); if (pressureImplicitPorosity) { U = HbyA + (trTU() & fvc::reconstruct((phig + p_rghEqn.flux())/rhorAUf)); } else { U = HbyA + (trAU()*fvc::reconstruct((phig + p_rghEqn.flux())/rhorAUf)); } U.correctBoundaryConditions(); fvOptions.correct(U); K = 0.5*magSqr(U); } } p = p_rgh + rho*gh; thermo.correctRho(psi*p - psip0); if (thermo.dpdt()) { dpdt = fvc::ddt(p); } #include "rhoEqn.H" #include "compressibleContinuityErrs.H" Please, let me know if any other details are needed. |
c++, deallocation, programming, renumbermesh, solver compilation |
