reconCentral not compiled
Old   August 14, 2020, 10:20
Default reconCentral not compiled
hbulus is on a distinguished road
Hello foamers,
I am trying to implement reconCentral scheme from Fe4.0 to OF1812. However i got the compiling error as 'does not match any in class':
wmake libso (reconCentral)
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file reconCentral.C
g++ -std=c++11 -m64 -DOPENFOAM=1812 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/finiteVolume/lnInclude -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/meshTools/lnInclude -IlnInclude -I. -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/OSspecific/POSIX/lnInclude -fPIC -c reconCentral.C -o Make/linux64GccDPInt32Opt/reconCentral.o
reconCentral.C:37:1: error: prototype for âFoam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const SFType&) constâ does not match any in class âFoam::reconCentral<Type>â
In file included from reconCentral.C:25:0:
reconCentral.H:142:2: error: candidate is: virtual Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const
interpolate(const GeometricField<Type, fvPatchField, volMesh>&) const;
make: *** [Make/linux64GccDPInt32Opt/reconCentral.o] Error 1
I made some obvious modificiations. I share the last version of reconCentral file as attached.
Thanks for every answers.
hbulus is offline   Reply With Quote
Old   August 14, 2020, 11:36
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
The function signatures in your .H and .C files do not match.
In reconCentral.H:
virtual tmp<GeometricField<Type, fvsPatchField, surfaceMesh> >
In reconCentral.C (neglecting template declarations):
    const GeometricField<Type, fvPatchField, volMesh>& vf,
    //const GeometricField<Type, fvPatchField, volMesh>& sf
    const SFType& sf
) const
In the .H file you have one parameter (the GeometricField object) while in the .C file you have two (the GeometricField object as well as the SFType object). The error is telling you that it can't find a matching class and suggesting the one above in the .H file as a candidate. Not sure exactly what the details of the code are, so I can't suggest which signature is correct, but these will have to be reconciled for the code to compile.
Chris DeGroot, PhD, PEng
CEO, Maple Key Labs
www.maplekeylabs.com
cdegroot is offline   Reply With Quote
Old   August 16, 2020, 12:48
In reconCentral.H:
    const SFType& sf
) const
When i cancelled the SFType object, nothing has changed. It still gives same error.
Old   November 25, 2020, 02:47
EDIT = Thanks to the friends in this forum, i could modify the reconCentral scheme for OF1812 by their helps. I am sharing the final form of the codes.
This scheme should be used for unstructured meshes with high skewness, especially for tetrahedral cells
reconCentral.C
\\ / F ield | foam-extend: Open Source CFD
\\ / O peration | Version: 4.0
\\ / A nd | Web: http://www.foam-extend.org
\\/ M anipulation | For copyright notice see file Copyright
License
This file is part of foam-extend.
foam-extend is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by the
Free Software Foundation, either version 3 of the License, or (at your
option) any later version.
foam-extend is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
General Public License for more details.
You should have received a copy of the GNU General Public License
along with foam-extend. If not, see <http://www.gnu.org/licenses/>.
#include "reconCentral.H"
#include "fvMesh.H"
template<class Type>
) const
const fvMesh& mesh = this->mesh();
tmp<GeometricField<Type, fvsPatchField, surfaceMesh> > tsf
new GeometricField<Type, fvsPatchField, surfaceMesh>
IOobject
"interpolate("+vf.name()+')',
vf.instance(),
vf.db()
mesh,
dimensioned<Type>(vf.name(), vf.dimensions(), pTraits<Type>::zero)
GeometricField<Type, fvsPatchField, surfaceMesh>& sf = tsf.ref();
const labelList& owner = mesh.owner();
const labelList& neighbour = mesh.neighbour();
const volVectorField& C = mesh.C();
const surfaceVectorField& Cf = mesh.Cf();
tmp
GeometricField
typename outerProduct<vector, Type>::type,
fvPatchField,
volMesh
> tgradVf = gradScheme_().grad(vf);
fvPatchField,
volMesh
>& gradVf = tgradVf();
// Since grad is used on coupled boundaries, correctBoundaryConditions
// needs to be called. HJ, 1/Nov/2012
//gradVf.correctBoundaryConditions();
forAll(sf.internalField(), facei)
// Owner contribution
label own = owner[facei];
sf[facei] += 0.5*(vf[own] + ((Cf[facei] - C[own]) & gradVf[own]));
// Neighbour contribution
label nei = neighbour[facei];
sf[facei] += 0.5*(vf[nei] + ((Cf[facei] - C[nei]) & gradVf[nei]));
typename GeometricField<Type, fvsPatchField, surfaceMesh>::
Boundary& bSf = sf.boundaryFieldRef();
forAll(bSf, patchi)
const fvPatch& p = mesh.boundary()[patchi];
fvsPatchField<Type>& pSf = bSf[patchi];
const labelUList& pOwner = p.faceCells();
const vectorField& pCf = Cf.boundaryField()[patchi];
if (pSf.coupled())
Field<Type> vfNei =
vf.boundaryField()[patchi].patchNeighbourField();
Field<typename outerProduct<vector, Type>::type> pGradVfNei =
gradVf.boundaryField()[patchi].patchNeighbourField();
// Build the d-vectors. Used to calculate neighbour face centre
// HJ, 19/Apr/2010
// Better version of d-vectors: Zeljko Tukovic, 25/Apr/2010
vectorField pd = p.delta();
forAll(pOwner, facei)
label own = pOwner[facei];
pSf[facei] +=
0.5*(vf[own] + ((pCf[facei] - C[own]) & gradVf[own]));
pSf[facei] +=
0.5*
vfNei[facei]
(pCf[facei] - pd[facei] - C[own])
& pGradVfNei[facei]
else if (vf.boundaryField()[patchi].fixesValue())
// For fixed boundary patches copy the value
pSf = vf.boundaryField()[patchi];
else
// For patches that do not fix the value, calculate
// extrapolated field
pSf[facei] =
return tsf;
Foam::reconCentral<Type>::correction
) const
// Note: Correction is calculated by assembling the complete interpolation
// including extrapolated gradient contribution and subtracting the
// implicit contribution. HJ, 27/Mar/2010
tmp<GeometricField<Type, fvsPatchField, surfaceMesh> > tsfCorr
IOobject
"reconCentralCorrection(" + vf.name() + ')',
mesh.time().timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE,
false
reconCentral<Type>::interpolate(vf)
- surfaceInterpolationScheme<Type>::interpolate
vf,
this->weights()
return tsfCorr;
namespace Foam
//makelimitedSurfaceInterpolationScheme(reconCentral )
makelimitedSurfaceInterpolationTypeScheme(reconCen tral, scalar)
makelimitedSurfaceInterpolationTypeScheme(reconCen tral, vector)
Old   December 2, 2020, 11:18
geth03 is on a distinguished road
@hbulus
i am glad you finally solved your problem
and thanks for sharing your adjustments to the code.
geth03 is offline   Reply With Quote
OpenFoam in docker (gcc 6) vs. OpenFoam natively compiled (gcc 8.1.1) Anouk OpenFOAM Running, Solving & CFD 0 September 17, 2018 09:02
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 08:17
Using compiled UDF:s in different Fluent versions S H FLUENT 1 September 12, 2007 04:40
how to compile compiled UDF? AVINASH FLUENT 3 January 19, 2007 05:04
DEFINE_CG_MOTION Interpreted or Compiled? Aussie Shane FLUENT 0 April 20, 2006 05:50
