fatal error: readPisoControls.H: No such file or directory
Old   August 13, 2020, 05:20
Default fatal error: readPisoControls.H: No such file or directory
Mike
hbtcfd2018 is on a distinguished road
Hello everyone!
I encountered a fatal error message when I compiling my own customized solver via OpenFOAM-v1912 version.The solver is built on OpenFOAM-2.3.1 and is compiled fine via OpenFOAM-2.3.1.The fatal error message reads:
[hpc4116022007@ln4 fac2Foam]$ wmake
g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -I../common/lnInclude -IMULES -IinterfaceBehaviors/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/transportModels/twoPhaseMixture/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/transportModels -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/transportModels/incompressible/lnInclude -IsharpInterfaceProperties/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/turbulenceModels/incompressible/turbulenceModel -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/surfMesh/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/fvOptions/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/sampling/lnInclude -IsphereIndexedCutMeshCell -IparticleProblem -Iinterpolation -IlamdaOnSolidSurface/lamdaOnSolidSurface -IpointToPointInterpolation/pointToPointInterpolation -fopenmp -IlnInclude -I. -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/hpc4116022007/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -c fdm.C -o Make/linux64GccDPInt32Opt/fdm.o
fdm.C:65:38: fatal error: readPisoControls.H: No such file or directory
         #include "readPisoControls.H"
compilation terminated.
make: *** [Make/linux64GccDPInt32Opt/fdm.o] Error 1
Is there anyone here who can help me solve the tough problem?
I will appreciate it very much!
hbtcfd2018 is offline   Reply With Quote
Old   August 18, 2020, 10:42
Klaus
klausb will become famous soon enough
In my experience you need to create a library with your controls using wmake libso,
after that, add the library to the Make/options file of your solver application (see last line in the code below) and compile the new solver using wmake.
 EXE_LIBS = \
    -lturbulenceModels \
    -lincompressibleTurbulenceModels \
    -lincompressibleTransportModels \
    -lfiniteVolume \
    -lmeshTools \
    -lfvOptions \
    -lsampling \
    $(FOAM_USER_LIBBIN)/libmysimpleControl.so
klausb is offline   Reply With Quote
openfoam-v1912, solver compilation
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
