Combining dynamicInkjetFvmesh with layeradditionremoval |
heo
Rep Power: 6 ![]() |
hello everyone.
I am modifying the source code of dynamicInkejetFvmesh to implement piston motion. One problem occurred during code development, which is that the top first grid in the domain area is loosened very long. In order to solve this problem, I thought it would be desirable to add layers in the expanded grid, and I'm looking for ways to add layers using layeradditionremoval.c and movingconetopoFvMesh.c. What I want is to add layers as the grid relaxes, although the domain shape is fixed. The attached code is an update part of movingconetopoFvMesh.c. As far as I know, <mapPolyMesh> is a function that implements grid movement. I wonder if there is a way to create layers without changing the grid geometry. Code:
bool Foam::movingConeTopoFvMesh::update() 317 { 318 // Do mesh changes (use inflation - put new points in topoChangeMap) 319 autoPtr<mapPolyMesh> topoChangeMap = topoChanger_.changeMesh(true); 320 321 // Calculate the new point positions depending on whether the 322 // topological change has happened or not 323 pointField newPoints; 324 325 vector curMotionVel_ = 326 motionVelAmplitude_* 327 Foam::sin(time().value()*M_PI/motionVelPeriod_); 328 329 Pout<< "time:" << time().value() << " curMotionVel_:" << curMotionVel_ 330 << " curLeft:" << curLeft_ << " curRight:" << curRight_ 331 << endl; 332 333 if (topoChangeMap.valid()) 334 { 335 Info<< "Topology change. Calculating motion points" << endl; 336 337 if (topoChangeMap().hasMotionPoints()) 338 { 339 Info<< "Topology change. Has premotion points" << endl; 340 341 motionMask_ = 342 vertexMarkup 343 ( 344 topoChangeMap().preMotionPoints(), 345 curLeft_, 346 curRight_ 347 ); 348 349 // Move points inside the motionMask 350 newPoints = 351 topoChangeMap().preMotionPoints() 352 + ( 353 pos(0.5 - mag(motionMask_)) // cells above the body 354 )*curMotionVel_*time().deltaT().value(); 355 } 356 else 357 { 358 Info<< "Topology change. Already set mesh points" << endl; 359 360 motionMask_ = 361 vertexMarkup 362 ( 363 points(), 364 curLeft_, 365 curRight_ 366 ); 367 368 // Move points inside the motionMask 369 newPoints = 370 points() 371 + ( 372 pos(0.5 - mag(motionMask_)) // cells above the body 373 )*curMotionVel_*time().deltaT().value(); 374 } 375 } 376 else 377 { 378 Info<< "No topology change" << endl; 379 // Set the mesh motion 380 newPoints = 381 points() 382 + ( 383 pos(0.5 - mag(motionMask_)) // cells above the body 384 )*curMotionVel_*time().deltaT().value(); 385 } 386 387 // The mesh now contains the cells with zero volume 388 Info << "Executing mesh motion" << endl; 389 movePoints(newPoints); 390 // The mesh now has got non-zero volume cells 391 392 curLeft_ = average 393 ( 394 faceZones() 395 [ 396 faceZones().findZoneID("leftExtrusionFaces") 397 ]().localPoints() 398 ).x() - SMALL; 399 400 curRight_ = average 401 ( 402 faceZones() 403 [ 404 faceZones().findZoneID("rightExtrusionFaces") 405 ]().localPoints() 406 ).x() + SMALL; 407 408 409 return true; 410 } |
dynamicfvmesh, movingconetopofvmesh |
[mesh manipulation] My layerAdditionRemoval demo | Ilya Sivkov | OpenFOAM Meshing & Mesh Conversion | 9 | October 8, 2019 09:53 |
dynamicInkJetFvMesh for motion in Y direction | Thangam | OpenFOAM Programming & Development | 3 | July 8, 2018 21:02 |
[mesh manipulation] how to set layerAdditionRemoval | cctv | OpenFOAM Meshing & Mesh Conversion | 5 | April 23, 2015 03:01 |
Error when combining mesh re-distribution with refinemt | rribeiro | OpenFOAM Programming & Development | 0 | March 24, 2015 14:47 |
[blockMesh] A script for combining two blockMeshDict | yingfeng | OpenFOAM Meshing & Mesh Conversion | 0 | August 26, 2009 16:05 |
