which formula used in drag force in dragModel.C?
Old   August 12, 2020, 06:14
Question which formula used in drag force in dragModel.C?
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi, everyone. I am confused that the expression of drag force used in Openfoam, as shown in the following codes. Why there is nu and divided by square of particle diameter. I saw the formula is without nu and only divided by diameter in some literature. Do you have any tip for me? Thanks a lot. By the way, After I deleted pair_.continuous().nu() and only divided by diameter. The results I obtained are totally the same.
Foam::tmp<Foam::volScalarField> Foam::dragModel::Ki() const
return
0.75
*CdRe()
*swarmCorrection_->Cs()
*pair_.continuous().rho()
*pair_.continuous().nu()
/sqr(pair_.dispersed().d());
qi.yang@polimi.it is offline   Reply With Quote
Old   August 12, 2020, 08:28
kimy
I understood the formula because CdRe already multiplied by a Re, so it should time nu and divide the other diameter in dragModel.C.
drag model, twophaseeuelrfoam
Applying drag force in the fluid model CanadaFlanker CFX 7 May 6, 2014 00:13
Force vectors for drag during sweeping motion aamer FLUENT 0 April 18, 2011 09:17
exporting drag force from fluent fluentguy FLUENT 2 October 27, 2009 15:19
drag coefficient & drag force abhishek.mnit FLUENT 0 April 30, 2009 00:48
Airfoil Drag Force wowakai Main CFD Forum 3 October 13, 1998 20:27
