Problem replacing fvm::laplacian with fvm::div(fvc::grad) in divDevRhoReff |
August 10, 2020, 12:29 |
Rishikesh
Rep Power: 10 |
I am working to change the default divDevRhoReff() defined in turbulenceModels/linearViscousStress.C. The change requires replacing the laplacian(U) operation with div(grad(U)). I change the content of divDevRhoReff(U) as follows:
template<class BasicTurbulenceModel> Foam::tmp<Foam::fvVectorMatrix> Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff ( volVectorField& U ) const { /* //first change Info<<"broken into two: nu + nut" <<endl; return ( - fvc::div((this->alpha_*this->rho_*this->nu())*dev2(T(fvc::grad(U)))) //split - fvc::div((this->alpha_*this->rho_*this->nut())*dev2(T(fvc::grad(U)))) //split - fvm::laplacian(this->alpha_*this->rho_*this->nu(), U) //not changed - fvm::laplacian(this->alpha_*this->rho_*this->nut(), U) ); //no issues as expected; some overhead due to repeated grad calculations. */ //second change Info<<"changed fvm::laplacian to fvm::div(fvc::grad) for nut term" <<endl; const volTensorField A = fvc::grad(U); //to create type required by fvm::div const surfaceScalarField N = fvc::interpolate(this->nut()); //surfacescalarField required by fvm::div, created out of volScalarField nut return ( // - fvc::div((this->alpha_*this->rho_*this->nu())*dev2(T(fvc::grad(U)))) //split // - fvc::div((this->alpha_*this->rho_*this->nut())*dev2(T(fvc::grad(U)))) //split // - fvm::laplacian(this->alpha_*this->rho_*this->nu(), U) //not changed - fvm::div(N, fvc::grad(U)()) // changed, removed alpha,rho to remove clutter. // - fvm::div(this->alpha_*this->rho_*(fvc::interpolate(this->nut())),A) //changed to div(grad(U)) instead of laplacian(U) , same as above ); } Code:
../turbulenceModels/lnInclude/linearViscousStress.C:120:5: error: could not convert ‘Foam::operator-(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::Tensor<double>]()’ from ‘Foam::tmp<Foam::fvMatrix<Foam::Tensor<double> > >’ to ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ PS: The reason I need to do this is because I need to carry out some operations on the grad(U) before calculating its final divergence. In other words, my nu cannot be taken out of the second derivative directly, so I cannot use laplacian(nut,U). |
August 13, 2020, 05:14 |
anonymous
Rep Power: 14 |
Hi!
First of all I think you should read about fvc and fvm. fvc is an explicit operator, while fmv is an implicit and based on your code I guess that you are not familiar with these. Instead of fvm::div(fvc::grad(<your stuff>)) you should use: fvc::div(fvc::grad(<your stuff>)) and treat this term explicitly. |
August 13, 2020, 15:49 |
#3 | |
Santiago Lopez Castano
Rep Power: 16 |
August 13, 2020, 15:54 |
#4 | |
anonymous
Rep Power: 14 |
I guess this is not his "final" code since he wrote: "The reason I need to do this is because I need to carry out some operations on the grad(U) before calculating its final divergence." |
August 13, 2020, 16:01 |
Rep Power: 16 |
then first what you need to manipulate is the snGrad class, and then use surfaceIntegrate to obtain the divergenge of said snGrad
fvm::div, fvm::laplacian, fvmatrix |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 09:40 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 10:11 |
