Failed wmake when using scalaCodedSource in fvOptions
Old   August 10, 2020, 05:18
Default Failed wmake when using scalaCodedSource in fvOptions
Unn
napattorn is on a distinguished road
Hi all,
I am currently struggling with setting up coded source via fvOptions. I have looked at previous discussions on this forum about this and used them as guideline, for instance, in creating the following momentum source term:
momentumSource
    type            vectorCodedSource;
    active          on;
    name    sourceTime;
    vectorCodedSourceCoeffs
    fields  (U);
    selectionMode   all
    redirectType  sourceTime;
    codeInclude
    codeCorrect
        Pout<< "**codeCorrect**" << endl;
        codeAddSup
        const scalarField& V = mesh_.V();
        vectorField& USource = eqn.source();
        USource += (100 1 1)*V; // Definition of the user-defined momentum source term
    codeSetValue
        Pout<< "**codeSetValue**" << endl;
    // Dummy entry. Make dependent on above to trigger recompilation
    code
        $codeInclude
        $codeCorrect
        $codeAddSup
        $codeSetValue
    sourceTimeCoeffs
    // Dummy entry
However, when I run the simulation, the following error message pops up:
Invoking "wmake -s libso /home/user/CFDEM/user-PUBLIC-5.x/run/Original/CFD/dynamicCode/heatSink"
sh: 1: Syntax error: "(" unexpected
[0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] Failed wmake "dynamicCode/heatSink/platforms/linux64GccDPInt32Opt/lib/libheatSink_7946a6c1177d969821ce64c8d265d148e8176c3e.so"
[0]
[0]
[0] file: /home/user/CFDEM/user-PUBLIC-5.x/run/Original//CFD/constant/scalarTransportProperties.generalManualProps.fvOptionsT.scalarCodedSourceCoeffs from line 67 to line 101.
[0]
[0]     From function void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
[0]     in file db/dynamicLibrary/codedBase/codedBase.C at line 206.
[0]
FOAM parallel run exiting
[0]
I also counter this error when I create similar field for scalarCodedSource. I looked up this error online but none seems relevant to my case.
Could any experienced users provide insights into this issue?
Thank you very much.
PS. I'm running a CFD-DEM simulation using CFDEM project - I'm not sure if this has anything to do with the error, but from my understanding fvOptions is initiated independent of the coupling.
napattorn is offline   Reply With Quote
fvoptions
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
user defined function cfduser CFX 0 April 29, 2006 11:58
