request fo volVectorField U.particles from objectRegistry regin0 failed-TwoPhaseEuler
Old   August 4, 2020, 16:38
Default request fo volVectorField U.particles from objectRegistry regin0 failed-TwoPhaseEuler
Hamed
Hamed1117 is on a distinguished road
Hi Foamers,
I need to get access to U.particles in order to calculate the shear rate somewhere inside the viscosity model for twoPhaseEulerFoam solver.
I use the following object registry utility for U field as :
const volVectorField& U = this ->db().objectRegistry::lookupObject<volVectorField> ("U.particles");
The problem, however, arises when I call U.particles for twoPhaseEulerFoam solver getting the following error message:
--> FOAM FATAL ERROR:
request for volVectorField U.particles from objectRegistry region0 failed
available objects of type volVectorField are
0()
I am pretty sure that the process of the U object registry is fine since other two-phase solvers (e.g. compressibleInterFoam) reads U field from 0/. folder through applying the same viscosity model.
I used the mentioned registry for all the twoPhaseEulerFoam/tutorials, but none of them read volVectorField U from 0/ but compressibleInterFoam/tutorials work fine.
Plus, comparing creatFields.H for two multiphase solvers (e.g compressibleInterFoam with twoPhaseEulerFoam) shows a major difference in the field declaration order that could be the possible reason for the problem.
any suggestions would be greatly appreciated.
Hamed1117 is offline   Reply With Quote
Old   August 6, 2020, 15:16
Hamed
I Solved the problem using the following procedure:
1- Since the object registry of U field is required for calculating of the shear rate (SR), it would be more efficient to use the available U field inside the twoPhaseEuler.C (not inside the thermophysical model)
2- As the shear rate (SR) is calculated inside the main solver, it can be easily transferred to the needed address (e.g. thermophysicalModels/basic/heRhoThermo/viscosity_calculation)
Old   January 28, 2021, 11:52
Niko
NFisc is on a distinguished road
Hello Hamed,
I try to do the same thing and I am stuck at the same part as you did. Can you explain your solution more detailled and maybe share your /basic, /specie and the twoPhaseEuler solver in case you modified something there?
Thank you very much for the help,
Niko
NFisc is offline   Reply With Quote
Old   July 7, 2021, 04:31
Default A non-newtonian viscosity for thermophysicalModels
anamika
Anamika is on a distinguished road
Hello Hamed,
I am also trying to use viscosity as a function of shear rate and phase fraction. I went through your suggestion but still getting a compilation error. I request you to please do share a your heRhoThermo.C and main Solver.C file. It would be a great help. Thank you.
Anamika is offline   Reply With Quote
Old   October 9, 2021, 15:25
Default Viscosity as A Function of Shear Rate in TwoPhaseEulerFoam
anamika
Hello Hamed, I am still figuring out if you have used U1 or U2 as an available U field to calculate SR. I used the U1 velocity field in the main solver and the solver got compiled successfully but it shows an error as the "SR.particle" file is missing.
It would be a great help if you can help me to figure it out. Hoping for the best!
Thank you in advance.
Regards,
Anamika
Old   May 24, 2023, 09:13
Question
riccardo
ricx is on a distinguished road
Hi Hamed, I have the same error.
request for volVectorField U from objectRegistry region0 failed
0()
From function const Type& Foam:bjectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>]
How did you solve it exactly? I am calling U in the function heRhoThermo as well as the strainrate sr. The compilation was fine, however when doing a simulation the U volvectorfield seem to not be available.
ricx is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
