access centreOfMass or centreOfRotation data from system/control #code function |
July 30, 2020, 02:33 |
David
Rep Power: 14 |
Hi all,
I am trying to access the centreOfRotation and centreOfMass information from within system/controlDict #code function. But I am not able to find out which data member or function I need (i.e. there are multiple centreOfRotation definitions within sixDoFRigidBodyMotion state and constraints). I am also not fluent with database registry to explore it. I tried the "printing registry" tip from OpenFOAM v7 manual with no luck. And using gdb is tough... Code:
Info << "mesh.names()" << mesh.names() << nl << endl ; Info << "runTime.names() " << runTime.names() << nl << endl ; |
centre of mass, data access, lookupobject, registry, sixdofsolver |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
access mesh in a function | chenu | OpenFOAM Programming & Development | 0 | January 6, 2020 04:50 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
