July 24, 2020, 05:19 |
Diffenence between omega_ and omega_()
You Wu
Rep Power: 8 |
Hi all,
I'm working on k - omega SST model recently. After reading the code, I found a problem. In the definition of epsilonByk, omega_() is used: Code:
template<class BasicEddyViscosityModel> tmp<volScalarField::Internal> kOmegaSSTBase<BasicEddyViscosityModel>::epsilonByk ( const volScalarField& F1, const volTensorField& gradU ) const { return betaStar_*omega_(); } Code:
template<class BasicEddyViscosityModel> tmp<volScalarField> kOmegaSSTBase<BasicEddyViscosityModel>::F2() const { tmp<volScalarField> arg2 = min ( max ( (scalar(2)/betaStar_)*sqrt(k_)/(omega_*y_), scalar(500)*(this->mu()/this->rho_)/(sqr(y_)*omega_) ), scalar(100) ); return tanh(sqr(arg2)); } But sometimes when I tried to change omega_() into omega_, I got compiling errors. So, what's the difference between omega_ and omega_()? What do those parentheses mean? |
July 24, 2020, 07:50 |
Rep Power: 8 |
i think omega_ is the variable and omega_() is the getter function for omega_.
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
Initial and Final Residual of omega 0 by calculation with k-w turbulence model | Stuntmanbob | OpenFOAM Running, Solving & CFD | 3 | August 18, 2019 06:02 |
Behaviour of the kOmegaSST in a steady-state case | Max1234 | OpenFOAM Running, Solving & CFD | 18 | October 31, 2018 09:03 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
how to calculate the omega at inlet boundary in k omega sst | Scabbard | OpenFOAM Running, Solving & CFD | 2 | September 30, 2014 14:06 |
