Parallelization of looping through all faces
Old   July 19, 2020, 22:00
Default Parallelization of looping through all faces
siavash
szamani is on a distinguished road
I have the following code:
surfaceScalarField interfacialSurface(fvc::interpolate(alpha1));
const labelUList& owner = mesh.owner();
const labelUList& neighbour = mesh.neighbour();
forAll(owner, facei)
const label own = owner[facei];
const label nbr = neighbour[facei];
if((alpha1.ref()[own] - 0.5)*(alpha1.ref()[nbr]-0.5) < 0.0){
interfacialSurface[facei]=1.0;
else{
interfacialSurface[facei]=0.0;
when I run the code in parallel, the shared faces between patches are not included in the loop above. I believe I need to write another for loop to include shared faces between patches.
My problem is that the owner and neighbours are not necessarily from the same patch, so how could I make the patches communicate the data between each other?
I appreciate any help
szamani is offline   Reply With Quote
openfoam, parallel code, surfacescalarfield
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
