Changing volScalar field using different dictionaries at different time
Old   July 16, 2020, 17:59
Default Changing volScalar field using different dictionaries at different time
Sagar Pokharel
ptroyen is on a distinguished road
I have somehow interpolated, say 8 datasets (calculated outside openfoam) for the same field at different times on openfoam mesh. So I have the information regarding the values of the scalar at the cell centers.
I want to make a dict file with all 8 interpolation datasets. And depending on the runtime ( take profile1 for first 10s, and then profile2 for next 10s .. ), I want to pick which dataset to use to create the volScalarfield. But I only use this filed in equation and not solve for this filed inside openfoam.
Since I run the interpolation at the start, the dict file and the volscalarfield will both be in the constant directory.
The dictionary file would look like this.
profile1 List<scalar>
1
2
profile2 List<scalar>
2
3
otherprofiles ....
My problem is how can I create the volScalar filed of a single variable with this? And how do I go about selecting the specific profile at the required time ?
Thanks in advance.
ptroyen is offline   Reply With Quote
constant fluid properties, runtime selection, volscalarfield
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
