chtmultiregion
Old   July 15, 2020, 20:04
Default chtmultiregion
Sam
saj216 is on a distinguished road
Hi guys,
I am trying to adapt the chtmultiregionfoam solver. However, I need to keep the fluid part as a single region (i.e without the multiregion aspect [i]). Does anyone have any pointers regarding using pimpleControl pimple(mesh); instead of using pimpleMultiRegionControl pimples(fluidRegions, solidRegions;.
As I currently keep getting the error
./solid/createSolidFields.H:2:39: error: ‘solidRegions’ was not declared in this scope.
Thanks
saj216 is offline   Reply With Quote
Old   November 9, 2020, 04:57
wanghongjie
wanghongjie is on a distinguished road
Originally Posted by saj216 View Post
Hi guys,
Thanks
Can you have a solution? I have the same question, maybe you can help me.
wanghongjie is offline   Reply With Quote
Old   November 9, 2020, 05:46
Sam
Hi wanghongjie,
I used the presentation in this link https://github.com/unicfdlab/Trainin...F4.1/materials to remove the multi-region aspect on the fluid region side for it to work properly. I implemented mine in openfoam 7.0 so it required some debugging too. The github itself has a lot of information with a step by step guide on how to achieve it which is explained in the presentation.
Hopefully it can help you too.
Kind regards,
Sam
Old   November 11, 2020, 12:42
Charles
Marpole is on a distinguished road
If you only want to simulate fluid without the multi-region aspect, you can use solver pimpleFoam. Otherwise, if you still want to keep solver chtmultiregionfoam, you don't have to change the code, but to change file regionProperties in folder "constant". In the file, you leave solid blank (see example below).
regions
    fluid       (air)
    solid       ()
Hi guys,
Thanks
Charles L.
Marpole is offline   Reply With Quote
chtMultiRegion + Adaptive Mesh Refinement Dostoyefsky OpenFOAM Programming & Development 2 February 21, 2022 03:16
Need help setting up chtMultiRegion OskarT OpenFOAM Pre-Processing 1 September 25, 2019 16:51
ChtMultiRegion changeDirectory julieng OpenFOAM Pre-Processing 12 February 11, 2019 18:56
WallHeatFlux and chtMultiregion m_f OpenFOAM Post-Processing 13 March 16, 2015 11:16
Mass transfer and chtmultiregion Bufacchi OpenFOAM Programming & Development 0 August 2, 2010 21:28
